585,886 active members*
6,218 visitors online*
Page 1 of 2 12
Results 1 to 20 of 28
    Feb 2004
    4
    RexRoth DriveTop software
    Do anyone know where i can find RexRoth Drivetop configuration software?
    Thank you
    Christer
    Nov 2005
    256
    It looks like they have pulled DriveTop off of their site. I downloaded DriveTop16V14 from their site December of last year. It's 50MB. I can't tell for sure, but it may be that IndraWorks Ds 09V12 has replaced it. You can find that at Bosch Rexroth Electric Drives and Controls That link should take you to a page with the Download link to the page with the file. Their website leaves me with a whole lot more questions than answers.
    Feb 2004
    4
    Hi Mike,
    Yes it seems that they have pulled it off their site.
    I have searched at many places without any hits that works.
    Thank you very much for your help anyway, and i will also give IndraWorks a try.
    Regards
    Christer
    Oct 2010
    13
    Drive Top
    What Drives you using? Drive Top 4v05 to be used for ecodrive 1, Drivetop 16 to be used for Ecodrive 3. Indra Works DS to be used for Indradrive CS. Indraworks is not designed for older drives....
    Stephan
    Mar 2009
    34
    INDRAMAT ECO DRIVE DKC01.1
    I HAVE SOME INDRAMAT ECO DRIVES (DKC01.1) AND CAN'T FIND THE SETUP
    SOFTWARE ANYWARE.
    ARE THESE DRIVES STILL SUPPORTED AS THEY DON'T LOOK THAT OLD?
    WERE CAN I FIND SERVO MOTORS THAT WILL MATCH THESE TIPE OF 3PHASE
    AC DRIVES?
    REGARDS
    DANIEL
    Oct 2010
    13
    @ Daniel,
    For DKC01.1 you need Drive Top 4v05 or near this Version number. Motors, cable for these drives i can help. Please send me your email via pn.
    Stephan
    Sep 2010
    1765
    I am not sure what onkel from germany said,but I have a cd with this software on it. if onkel did not fix u up let me know and I will figure how to cc for u.
    Mar 2009
    34
    INDRAMAT DKC01.1 DRIVE SOFTWARE
    HI EVERYONE.
    I AM LOST BETWEEN I THINK 4 PEOPLE WHO IS TRYING TO MAIL ME A COPY
    OF DRIVE TOP SOFTWARE FROM ALL OVER THE WORLD.
    NOT ONE SEEMS TO GET IT RIGHT.
    I AM NOT SHARP WITH COMPUTERS BUT IF I WANT TO MAIL A FILE I ATTACH IT TO MY MESSAGE AND MAIL IT.
    THE MANUAL SAY IT IS ON TWO STIFFIES SO THE FILE CAN'T BE THAT BIG.
    ANYWAY I AM LOSING HOPE OF EVER FINDING THIS.
    REGARDS
    DANIEL
    Oct 2010
    13
    Drive Top 16 was avaiable to download from Indramat website. Daniel needs DriveTop 4v05 witch has never been avaiable for free. DriveTop 12 and higher can not connect to DKC01.1
    Greetings Stephan
    Apr 2009
    28
    Hello,
    I would like to configure an ecodrive DKC02.1 so I need drivetop...
    But wich version?
    I don't find any version on indramat website...
    Somebody can help me?
    Many thanks!
    Oct 2010
    13
    You need Drive Top 4v05.
    Greets OS
    Aug 2012
    Urgent help!! I have a DKC21.3-100-705vrs-FM drive with the firmware FWA-ECODR3-FLP-05VRS-MS. Which software that I need to use in order to communicate with PC through RS232? Thanks
    Oct 2010
    13
    U need DriveTop 14 and higher. Avaiable from Bosch Rexroth Website
    https://www.boschrexroth.com/various...jsp?oid=118749
    Software is German and English
    Greetings Stephan
    76
    I have a DKC1.1-030-3 indramat drive in an old system used for life testing. I am trying to repurpopse the drive and motor for a new fixture but cannot locate our copy of the drive top software. it seems that since it was on floppy it was tossed out during a move. We still have the cable installed on the drive from the last time it was used. Would anyone be able to forward me a copy of the software?
    >>@ Daniel,
    Stephan <<
    thanks
    grifftek AT grifftek dot com
    Bill Griffin
    [email protected]
    www.grifftek.com/grifftek
    Aug 2012
    Steven, thanks for your reply.
    I've tried it before but this software seems like doesn't support the firmware in my Ecodrive03. Any solution?
    Oct 2010
    13
    Ecodrive 3 need DriveTop 14 and higher. Ecodrive 01 need 4V05. The Software for ECODrive03 is avaiable for download at Bosch Rexroth Website. For 01 please send PN.
    Greetings Stephan
    Aug 2012
    Could you explain it clearly. My situation is, I have already installed DriveTop16v14. After opening up this software, I choose "online using rs232/485 ecodrive/diax". I set "port1" and "9600" baud rate. Then, I connect my desktop PC's rs232 port to EcoDrive03 rs232 port which is located in X2. When I am trying to detect the Ecodrive03, the software detects nothing. I found that this software doesn't support the firmware which is FWA-ECODR3-FLP-05VRS-MS. What should I do now?
    Oct 2010
    13
    Hi Tendenz,
    It seems your settings are correct but you need to try several Bautrate. Try Autobaut. You are right, your Firmware is not supported by Drivetop 16V14. I just check. But this doesnt explain why you can not connect. Drivetop need to connect first before can check Firmwaresupport. Either way your Speedsetting or cable is not correct. DKC21.3 is a special Drive developed for limited Customers only. Thats y the Firmware is not in the List. In earlyer Days they like to develope special Versions witch have special Software only for this customer.
    Sep 2013
    Dear Friends , it is always useful to have old software, and I need Drive Top for working on a Indramat DKC02 drive.
    Does anyone could help me on that ?
    If someone could send me a CD with Drive Top I´d really be thankful.
    Thanx - Valdir Bispo
    Oct 2010
    13
    Hi
    Here you can download Drivetop 16 for Ecodrive xx.3
    Bosch Rexroth Medienverzeichnis
    To download Drive Top 4V05 for Ecodrive xx.1
    You can not use IndraWorks
    Onkel Steven
Page 1 of 2 12
  1. My DIY Build Bosch/Rexroth and 8020
    By JC1 in forum DIY CNC Router Table Machines
    Last Post: 08-03-2011, 12:02 AM
  2. rexroth extrusion
    By stk2008 in forum DIY CNC Router Table Machines
    Last Post: 10-02-2009, 09:55 PM
  3. Rexroth tahometer pinout
    By Gerisz in forum CNC Machine Related Electronics
    Last Post: 11-17-2008, 11:39 AM
  4. Where to buy Rexroth Hydraulic valve?
    By mjse in forum Community Club House
    Last Post: 07-23-2004, 01:28 PM
  5. Where to buy Rexroth Hydraulic valve?
    By mjse in forum DIY CNC Router Table Machines
