I'm searching a way to code this thread profile in FeatureCAM using turn/mill module.
It's an ID thread as you could see :
I want to grind this thread with a custom made borazon cutter. The complete turning assembly is made of 2 half-cavity blocks.
I tried to make a turn/mill feature, using boss but without success. The process is similar as a standard ID thread, except it's made at very low speed, perpendicular entry with an external surface and out the same way, the cutter, mount on a grinder, is use instead of a threading tool... don't know if you would know what I mean...
Since I'm a newbie in CAM, I'm here asking if it could be made. If so, I'll appreciate some help.
If you need any further information to help me out, just ask it.
Thanks very much!
Wiseco
