Im having a Hitachi Seiki Make VMC model VA 65 with Fanuc 11m control and PLC.
displays SP cooling flow alarm D171.0 when NC/PC button pressed
Kindly help to resolve this problem
thanks in advance
DD
thanks in advance
DD
check the spindle cooler is functional and topped up with fluid, check the unit for any error code/ lamps. Check the compressor and fans are working etc; Is the air filter clean ?
Maybe called a Daikin unit ?
