585,597 active members*
3,144 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > Old SEM Servo Encoder retrofit/replacement.
Results 1 to 6 of 6
    Jul 2009
    7
    Question Old SEM Servo Encoder retrofit/replacement.
    Hello gang,
    I have some older SEM MT30 servos, Bridgeport oem parts. They have Heidenhain 115-125 encoders. These give analog output, supposedly something like 125 counts per rev when translated, and the controller hardware had a multiplication of 5 to make it 625 counts per rev. I think this is a too few for my application, and am wondering if anyone else has found suitable replacement encoders? Preferably ones that bolt right up, and either have their own compatible enclosures, or fit in the existing ones.
    Any help is appreciated.
    24220
    If these are through-hole shaft mount encoders, Renco or Hengstler should be able to supply a substitute US Digital is cheaper made, but some use these.
    A nicely made cheaper shaft style is made by Koyo.
    Heidenhain extract a much higher encoder resolution than the native counts/rev with the sine wave output type, due to angular extraction between the two sine/cosine signals.
    Al.
    Albert E.
    Jul 2009
    7
    Thanks for the names. My particular model was a goofy one, with washers/nut on a threaded shaft holding the diffraction grate, and a manually adjusted little frame holding the reader. Luckily it has a usable 10mm shaft coming off of the main 17mm shaft going to the tach drive commutator. It looks like Renco should be able to hook me up, but they are off on Holiday and I will have to wait a bit. On the plus side, the newer ones are self aligning, I just have to set the phase!
    24220
    Quote Originally Posted by 2xEngineer View Post
    Set the phase?? On a DC motor?
    Or do you mean for correct direction?
    Al.
    Albert E.
    Jul 2009
    7
    Well, ya got me. I took one look at those alignment instructions and I never thought of what I would be measuring, all I saw was waveforms. Although yes, I will have to set the direction.
    Nov 2006
    925
    Hi 2xEngineer,I`ll buy the Heidenhain encoder parts from you if you want to sell them.
    Mark.
  1. BEI encoder replacement
    By Goslowjimbo in forum Servo Motors / Drives
    Last Post: 01-28-2017, 09:02 PM
  2. encoder replacement
    By emxaler in forum Okuma
    Last Post: 02-24-2010, 08:50 AM
  3. encoder replacement
    Last Post: 02-20-2010, 06:03 AM
  4. Encoder Wheel Replacement?????????
    By bill south in forum CNC Machine Related Electronics
    Last Post: 05-12-2006, 12:15 AM
  5. Encoder Retrofit To Baldor Servo
    By bgolash in forum Servo Motors / Drives
    Last Post: 03-23-2006, 03:40 AM
