585,962 active members*
4,042 visitors online*
Results 1 to 9 of 9
    Aug 2010
    24
    NMI 20 Emergency Stop Alarm
    Hi
    I have the similar alarm in my Mazak Mazatrol M2. When I switch on the power the following alarm appears on the screen.
    "NMI 20 Emergency Stop"
    When I press "reset" button, the alarm disappears for a moment and comes back again. When I press "reset" and "OT" button together, the hydraulic turns on and alarm disappears. But when i release these buttons, the alarm appears again. I checked all the "E stops" and they are fine. Can anyone has an idea please.
    Pcreek
    Oct 2005
    420
    Can you manually move the axis one by one off their limit switches? Sounds like you may have a hard overtravel on one or more axis.
    Jun 2008
    150
    You're on it nlh! Don't you have to release the reset but keep the OT release in while you jog it off the hard limit? And if I remember right, if it's a VQC type, and Y is over in the ATC area it has to be cranked way out of there before it will clear?
    Oct 2005
    420
    LeeLund,
    I don't remember exactly. It's been a long time since I had a hard-overtravel on my VQC. Try holding both reset and OT on until the machine comes up, then release reset and keep OT depressed. Then with the jog wheel, move each axis in the - direction until a good distance from the zero point. Then release OT and see what happens. If you have the manuals for the machine, it should point out the correct procedure.
    Let us know what else you find.
    May 2010
    112
    NLH is exactly correct, I just happened to do the same exact thing to another M2 yesterday.
    You might have to go into handle mode while you are holding the overtravel release button down...
    Oct 2005
    420
    Glad I could be of help!
    Also, you may be able to use the JOG or RAPID key to accomplish the same thing, but your better off with the HAND WHEEL from a safety perspective.
    Aug 2010
    24
    20 NMI emergency stop Mazak
    Thanks everyone for their time and effort. I managed to clear "20 NMI Emergency stop' by moving away all the axises from LS by hand and press reset button on the panel.
    Pcreek
    Feb 2017
    4
    Re: NMI 20 Emergency Stop Alarm
    I am getting this alarm also with a 100 alarm tool data incomplete. the reset/ O.T. release combo is not working for me so i moved the y axis back by hand and disconnected the z limit switch. i originally thought this to be a battery problem because i lost all tool data at the same time, but i put new batteries in today and im having the same issues. everytime i put new tool data in and i shut down and restart the machine i will get a white screen that says auto test. then when i get my main screen to come back up all my tool data is gone again. any help with this issue would be much appreciated.
    Dec 2011
    12
    Quote Originally Posted by fizzlenut View Post
    Any luck on the white Auto Test screen. Our machine just powered up with it. It is very hot and humid today, not sure if that has anything to do with it. Has anyone else had this issue? Thanks
  1. ALARM 20 NMI EMERGENCY STOP.
    By GPena in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 01-13-2022, 02:48 PM
  2. 56 alarm emergency stop external
    By s-kin in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-09-2015, 01:34 PM
  3. 058 emergency stop (external) Alarm
    By gearmachinist in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 11-02-2012, 06:55 PM
  4. With Mazatrol T32 Alarm 128 Emergency Stop
    By Bullet605 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 10-17-2012, 11:32 PM
  5. Alarm 128 QT-8 Emergency stop
    By grabolo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 06-22-2009, 07:24 PM
