585,991 active members*
4,725 visitors online*
IndustryArena Forum > CNC Electronics > Servo Motors / Drives > What drives/power for these servos?
    May 2006
    27
    Have some servos (on a machine) that read as such (see pic for full data):
    stall torque: 1.6nm
    rated speed: 3000 rpm
    kt: 0.16 nm/a
    bemf: 16.5 v/krpm
    rated curr: 10A
    So will G320's fit the bill? What size toroidal transformer for 3 or 4 axis?
    Thanks!
    Mar 2004
    1806
    From the nameplate data, it appears that you will need ~50V Dc (3*16.5) and for a 4 axis machine, I would rate the current flow at ~(4*10*.66) or 26 Amps based on previous discussions that I have read here and elsewhere. Also, I see this unit has a tachometer and you will need an encoder to work with the Gecko. If you add an encoder, try to find one that uses <50ma current supply @5V or you will have to have a separate power supply for that. The AMT encoders seem to be in favor at the present time for the Geckos and can be found at DigiKey.
    Hope this helps.
    Art
    AKA Country Bubba (Older Than Dirt)
    May 2006
    27
    Thank you. That brings up another question for my curiosity. What is the torque of these motors in comparison to a modern servo, such as a Keling? I mean like how many oz-in?
    Thanks again. :-)
    24221
    1.6N-m = 1.18 lb-ft (226 0z-in).
    To allow for losses etc, I would go at least 60vDC for the supply.
    Usually the minimum voltage rating for the supply is motor terminal voltage +10% min.
    Al.
    Albert E.
  1. Servos/ encoders/ drives???
    By Ark1 in forum CNC Machine Related Electronics
    Last Post: 10-15-2010, 02:16 AM
  2. servos, drives, p/s
    By scudzuki in forum Benchtop Machines
    Last Post: 02-09-2009, 01:02 AM
  3. Gecko Drives and Fanuc servos?
    By Radius in forum Gecko Drives
    Last Post: 06-27-2007, 02:07 AM
  4. Replies: 0
    Last Post: 11-08-2006, 02:50 PM
  5. servos (encoders, drives)
    By gv71 in forum CNC Machine Related Electronics
    Last Post: 03-31-2004, 07:43 AM
