585,758 active members*
4,323 visitors online*
IndustryArena Forum > CAM Software > PowerMILL > need post for maho 1000
Results 1 to 6 of 6
    Nov 2007
    45
    looking for post processor for an old maho 1000 mill & pm8. the Y & Z cords are swapped around!
    or is there a way I can modify an existing post to swap the Y & Z?
    regards
    anilam
    Oct 2008
    29
    FREE AZpost postprocessor for 3-axis CNC machine tools
    NCData Services can provide you with a FREE AZpost 3-axis VMC postprocessor that can be configured easily for any 3-axis CNC machine tool. Limited support configuring this VMC3X postprocessor for your CNC machine is also available.
    Go to NCData, NC Data, NCData Services, NC Data Services, NC postprocessor services, CNC Software and browse the "News" item.
    Best regards
    Larry
    Nov 2007
    45
    thanks Larry
    will this post work from inside powermill8?
    Sep 2009
    68
    do you use Duct post or PM post?
    if you are using Duct post I think I can help you
    Nov 2007
    45
    Quote Originally Posted by vladimir1409 View Post
    thanks, I've solved the problem.
    Jan 2010
    33
    anilam, how did you fixed the problem, I have the same with the mmachine of a friend an old Maho 700 that the Z and Y axis are swaped.
  1. MAHO 432 Post Processor
    By micktat in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-19-2024, 01:17 PM
  2. maho 1000
    By jalil in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-01-2015, 09:13 AM
  3. Deckel Maho 63V Post
    By louorfran in forum Surfcam
    Last Post: 04-14-2014, 04:21 PM
  4. Need Maho 432 post
    By rroberts in forum EdgeCam
    Last Post: 11-23-2010, 12:56 PM
  5. Deckel Maho 63V Post
    By louorfran in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 06-09-2007, 11:55 PM
