584,865 active members*
4,913 visitors online*
Results 1 to 6 of 6
    Apr 2010
    42
    Post Chinease ball screws an linear rails
    Hallo
    I am going to build my very first cnc router table.
    I was looking for ball screws and linear rails. My table dimensions will be around 1000 x 1200mm.
    I found linearmotionbearing2008 (chai) on ebay which offers really cheap prices - but i dont know if they are good
    I´ve already read the tread here in the zone about his screws, and all reviewd that these screw arent the best but very good.
    I got price from him for one 1250mm ballscrew (endmachined) with nut (16mm) and 5mm Pitch. Total with nuthousing and bearing blocks is 140 USD
    the ballscrew itself is 54usd
    I asked him about the accracy from the ball srew - he answerd that they are Precision rolled, class 7 accuracy; JIS (0.050/300mm) (0.002"/12") that means that i have only 0,2mm accuracy on 1200mm total lenth
    So know i am not sure if that would be a good deal.
    Is March3 able to correct that devation from the screw?
    Hope you can help me
    Dec 2005
    37
    No, Mach3 would not be able to compensate for deviations along different sections of the screw, if that's what your asking. I doubt that the screw would be off the maximum amount over the entire length anyhow, but even at .2mm, that's accurate enough for even the most demanding woodwork, I would think.
    I know you've already read some about linearmotionbearing2008, but I'll throw in my $.02 anyway.
    Ball Screw Review » Hillbilly Hilton
    Apr 2010
    42
    thank you for your good reply!
    - Yes thats for what i was asking.
    No I´ve just read the feedback here in the zone and everybode was very happy with these screws.
    Thank you for the link - i hadnt found that before.
    He says in the review that the endmachining wasn´t done correctly
    and the bearing blocks were very bad quality.
    But he also says nothing bad about the screws themselves - right?
    He proofs that there is no measureable backlash at all.
    I could buy the bearing blocks anywhere else - that doesnt matter at the moment.
    Does anyone else have written a review about the screws?
    What about the linear rails? What do you think?
    My machine will be constructed to also handle Aluminium in small amounts - i would want to reach at least a accuracy of 0.1mm
    - so should I buy these screws? (without the bearing blocks)
    Best regards,
    Max
    Sep 2007
    359
    Quote Originally Posted by Sinistersam View Post
    You are wrong.
    See here http://www.machsupport.com/forum/ind...ic,1787.0.html
    Phil
    Sent from my HTC Desire using Tapatalk
    Dec 2005
    37
    I stand corrected. Thanks Phil.
    Apr 2010
    42
    ok good - thx
    so the lead accuracy isnt a problem, if it is too high, because it can be corrected by software.
    So what about the linear rails? are these from chai good and will they overstay aluminium milling?
    THX
  1. In progress - 8020, linear rails, ball screws, steppers
    By stevespo in forum CNC Wood Router Project Log
    Last Post: 07-25-2012, 05:10 PM
  2. Ball screws & linear rails.
    By diyengineer in forum Want To Buy...Need help!
    Last Post: 03-10-2010, 02:56 AM
  3. The use of screws for linear rails as well
    By CNCDevil in forum Linear and Rotary Motion
    Last Post: 08-18-2007, 11:50 AM
  4. Sources for new BIG ball screws and rails?
    By ewest in forum Linear and Rotary Motion
    Last Post: 05-21-2007, 04:56 PM
  5. Acme screws as linear rails?
    By bb99 in forum DIY CNC Router Table Machines
    Last Post: 12-26-2003, 10:24 PM
