585,996 active members*
4,222 visitors online*
    Jan 2011
    Mitsubishi Wire EDM SX10 Contact problem
    I have a Mitsubishi Wire EDM SX10 that was previously on another site, it was transfered to my site and was installed by ourselves, when we finish we tried to run the machine but we are getting an error, T211 that says 30 sec contact I look on the manual an it says to clear the short-circuit o check for cut workpiece dropping.
    Since we havent cut anything, the second one shouldnt be the problem. So the machine should be in a short-cicuit. How can I clear that short? Does anybody knows?
    Aug 2007
    8
    Quote Originally Posted by m_ross18 View Post
    Checked wire evacuaiton? Any little grounding maybe cause.
    Jan 2011
    Quote Originally Posted by bobwood View Post
    Yes I believe is a grounding problem since we install the machine and we have a ground tagless wire that didnt know where it was screwed. and a "G" tagged wire that didnt found where to screw it.
    Nov 2010
    Salve, ho comprato una Mitsubishi EDM FX10, (purtroppo senza nessuna garanzia), quando è stata piazzata , mi sono accorto che una scheda era stata completamente privata di tutti i relais, e alcuni componenti, la scheda, è un alimentatore, sulla scheda la sigla è.
    AEDA-04-DWC
    BY171E614G51 - B.
    MITSUBISHI ELECTRIC CORPORATION
    Qualcuno mi puo aiutare a trovare un riparatore, o una scheda nuova?
    Grazie
    Nocerino
  1. Wire EDM Mitsubishi DWC-200 H1
    By Roswell28 in forum Waterjet General Topics
    Last Post: 03-10-2014, 05:44 PM
  2. Mitsubishi FX1 Wire
    By one4design in forum EDM Discussion General Topics
    Last Post: 10-05-2008, 07:37 PM
  3. MITSUBISHI SX10 SERIES(SEND DATA BY RS-232C)
    By Alfredo Lugo in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 08-10-2008, 03:21 PM
  4. Mitsubishi DWC-110H A Wire EDM Floppy Problem
    By tjurek in forum DNC Problems and Solutions
    Last Post: 10-11-2007, 01:08 PM
  5. Mitsubishi H110 Wedm Wire Problem
    By osomaker in forum Waterjet General Topics
    Last Post: 12-11-2006, 07:23 PM
