585,885 active members*
6,253 visitors online*
Results 1 to 8 of 8
    Dec 2010
    Newbie at CNCing
    Hello All,
    I might as well try posting to this new forum.
    My 12 x 12 is basically up and running with a couple, three projects under its belt. I had to force myself to quit cutting stuff to hook up the homing switches and of course learning by the road of hards knocks the software....
    Have a good one.
    Mark
    Apr 2009
    9
    Also new to CNC
    I ordered a 12x12 also and it is due wednesday. I think I'll probably need some help.
    Dec 2010
    Bluemax,
    These are great little machines. If you're mechanically inclined then you should not have any real problems assembling. The manual that I had to use to assemble was a little rough around the edges and I did have to do some head scratching. I have not checked, but maybe there is an updated one now on the Zen site.
    There are a couple of tricks that I found to get things more accurate which can be done later..
    Give me a holler when you have questions and I'll try my best to answer them.
    Mark
    Apr 2009
    9
    Canam1
    Thanks for the encouragement. I know I will need some help with the wiring. Elec Eng was not my strength at Mich. Your pictures on the switches look like they will help. I ordered the whole package from Zen so hopefully I'll have everything I need. It appears that the people that own these machines ( Zen Toolworks) are very helpful with us newbies. It is one of the reasons I picked this machine. The other was customer support from the owner and it is a U.S. company. I don't mind spending more money if I can get support and it stays here. Anyway Ilike a challenge and this looks like one.
    Dec 2010
    All,
    Finally have all the electrics done. Home switches work great....
    Just for kicks to test everything out I found a fret work drawing and converted it over to machine it.
    I have included a pic of my finished wiring (The only thing missing is my 9 VDC wall wart to power the relays) and the finished fret piece. Turned out pretty good..
    Mark
    Uploaded with ImageShack.us
    Jan 2011
    Hi CanAm1,
    Thanks for sharing your experience
    I just ordered a 7X7 bench and have some question for you
    Please let me have a direct link to your Stepper driver and power supply
    Not too sure to understand the purpose of your relays board (safety device ??) please elaborate
    Finally, How is the spinddle speed adjusted ??
    Thanks for your help
    Dec 2010
    Hello Kas,
    Let me start by saying that you have ordered a great little machine plus the help from Zin and Clint at the Toolworks is the best.
    Let me see if I can answer your questions.
    The stepper driver and power supply I am using are the newer units the Toolworks offering. The stepper driver is their 2010 enclosed unit which only needs one power supply source and the power supply is a 24 volt unit that puts out 12.5 amps. (The Toolworks WIKI site shows and explains these goodies)
    The relays control the home signals and the spindle power. There are 3 microswitches one for each axis. These switches feed the relays which in turn send the signal to the electronics. The forth relay allows control of the spindle power from the software.
    Right now I am just using the 24 volt power supply to power the spindle. At 12.5 amps it has plenty of power and I have not noticed any performance issues with steppers. My spindle is running right around 5000 rpm and so far has been great for all my "newbie experimenting". Eventually I'll hook up higher output variable..
    Mark
    Jan 2011
    Thanks Mark for this prompt response, I am sure that we will have additional oportunities to exchange experience.
    Yves
  1. Trying to go zero to 60 in CNCing
    By DigiTan in forum Community Club House
    Last Post: 09-12-2010, 06:00 AM
  2. New to CNCing aluminum... Please help
    By lm6769 in forum MetalWork Discussion
    Last Post: 01-15-2010, 11:32 PM
  3. HF 8 x 12 - Need input on CNCing it
    By wwendorf in forum Mini Lathe
    Last Post: 10-16-2008, 12:20 AM
  4. A draft of a newbie overview of hobby level CNCing... please comment
    By InspirationTool in forum Community Club House
    Last Post: 08-14-2006, 01:53 PM
  5. n00b trying to get into cncing
    By ironDigit in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 01-19-2006, 11:45 AM
