585,974 active members*
4,257 visitors online*
IndustryArena Forum > CAM Software > UG NX > UG NX 7.5 Post Proceesor
Results 1 to 12 of 12
    Jan 2011
    Exclamation UG NX 7.5 Post Proceesor
    Hi, I am new at this and we have just purchased a Roland MDX 540A. We urgently require a post processor for UG NX 7.5 and was hopping someone could point us in the right direction?
    Where do I get one for NX? Is it possible to create my own and how dificult would that be?
    Please I require anyone'e assistance.
    Aug 2008
    71
    There is a library of free posts available, so you may find something close there. Then use Post Builder to customize it. From NX Manufacturing, go to Help, Online Technical Support, Download NC Postprocessor.
    Your reseller also has access to more posts, and should be able to create one for you if you don't want to do it yourself.
    Mark Rief
    Siemens PLM
    Oct 2007
    41
    There is a Post Library at http://download.ugs.com/unigraphics/...post_index.htm.
    You need a Siemens WebKey account to access. Sign up for a WebKey account with your customer ID / Server ID. (Help -> About NX -> System Information -> Server ID)
    However, there is no post in the library for the Roland.
    I found the programming manual at http://support.rolanddga.com/docs/Do...CODE_EN_R1.pdf
    This looks like a pretty straight-forward machine. For simple machining, you should be able to use the "Mill 3-Axis" post that is supplied with NX
    To create your own, or edit an existing post is relatively simple using Post Builder if you have an understanding of postprocessors and the machining terminology they use.
    There are a few options on this machine that would require some custom code:
    Helical interpretation, G10 Data Setting, G39 Corner Offset Interpretation, G50/51 Scaling.
    Siemens offers Postprocessor development as a service. If interested, Contact
    Joe Guagliardo ([email protected])
    If you decide to tackle this on your own, and have questions, post them here & I'll be glad to help.
    Be Well
    "Of course, that's just my opinion. I could be wrong!"
    T Briggs (CAM dude) - Siemens PLM Software
    Jan 2011
    Hi Brewmeister,
    Thank you for the info. I will have a look and see if I can figure it out.
    Best Regards,
    Gary
    Jan 2011
    Tool creator
    I need help with creating a End mill tool in NX. The foot diameter is smaller than the shank diameter. Can this be done in NX and how?
    Regards,
    Gary
    Oct 2007
    41
    You can use a regular End Mill (Milling Tool-5 Parameters), and enter a taper angle.
    This will only represent the tapered portion of the tool. If you need to display and/or check against the shack, then you can cheat & create a tool holder with the first segment representing the shank of the tool.
    OR, you can use a User Defined Tool (MILL_USER_DEFINED), also called a "Form Tool".
    User Defined Tools are only used with Planar Profile operations.
    Jan 2011
    Post Processor Roland MDX 540A for UGS NX Manufacturing
    Hi All,
    This is just to say thank you for your help. If there is anypne out there that requires the post processor for the MDX 540A for UGS NX manufacturing then please find it attached.
    Best Regards,
    Gary
    Attached Files Attached Files
    Aug 2007
    69
    post for punchpress
    have u ever seen any post for cnc puncpress?
    Aug 2008
    23
    CAn you please check in the libarry if there is a PP for Mazak Integrex IV with Matrix controller ?
    Thanks a lot !
    Apr 2015
    Re: UG NX 7.5 Post Proceesor
    Hi, I am new at this and I learn UG NX 8. I need Post processor for siemens 828D Basic M.
    Aug 2007
    69
    Hi yogesh123
    siemens 828D is similar to siemens 840D in programming .
    You can use this Post from the P.P library of NX.
    good luck
    May 2017
    Quote Originally Posted by gcgasson View Post
    Hi All,
    Best Regards,
    Gary
    I am unable to download this file, can you please helping me by sending on my email : [email protected] thanks in advance
  1. Special post for presentation! Laser manufacturers/dealers post their contacts here!
    By Litografa in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 06-22-2010, 07:23 PM
