585,978 active members*
4,586 visitors online*
    CFM requirement
    Can someone give us some direction concerning vacuum pumps. We are upgrading our router with vacuum hold down. We'll be doing mostly acrylics up to 50mm, mostly 12mm or less. and full sheets without gasketing. It seems CFM is key. We estimate that after a sheet of material is completely routed there will be 10% to 20% open area (vacuum loss). How much CFM should the pump generate to overcome this loss and ensure absolutely no part loss due to moving parts. Thanks in advance guys.
    6
    Vacuum clamping
    Dear send me your e-mail address I tell you how libor dot pirko at centrum dot cz Look on private mesage. Regards Libor
  1. Thermal Dynamics A-120 power requirement help
    By hailrazer in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 11-27-2010, 02:06 AM
  2. G540 Power Supply Requirement
    By samim in forum Gecko Drives
    Last Post: 07-19-2009, 05:37 PM
  3. Reducing motor current requirement?
    By JerryB123 in forum Stepper Motors / Drives
    Last Post: 11-19-2007, 11:33 PM
  4. How to determine the Holding Torque Requirement?
    By joprinz in forum Stepper Motors / Drives
    Last Post: 11-19-2007, 11:59 AM
  5. min requirement of PC for install and run EMC2?
    By szcharle in forum LinuxCNC (formerly EMC2)
    Last Post: 03-01-2007, 03:53 PM
