I work in a university and we have a Multicam 3000 CNC router. I managed to troubleshoot that one of the two X-servo motors is faulty. When "homing" the machine, the motor turns but bombs out after a few seconds with an error; (Encoder signal problem, confirm motor connection sealed properly. check for visible cable damage).
What could the problem be. I contacted Multicam South Africa and they mentioned that it could be the reduction gearbox.
Help? Must I replace the motor, servo; can it be repaired>
Thank you,
Regards..
Ugan ( South Africa)
