Hi, guys!
I need help to run INDIMCO ICS P800 foam cutter!
At the moment we use registered STEP-FOUR cutting software v3 that runs under DOS. This software is compatible with STEP-FOUR Motor control unit SF-C2. STEP-FOUR home page here.
Problem: we need software and configuration to run this INDIMCO machine under Windows XP Pro SP2.
I tried out GMFC, but I couldn't configure table settings, because I don't know steps per revolution, nor timer value, nor pin connections.
