585,954 active members*
4,024 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Connecting steppers to drivers
    Oct 2010
    Im just about to connect my stppers to my drivers, but am not sure what is what as the connections are labled 1a 1b 2a 2b, how does this relate to a+ a- b+ b-. the instructions say "First phase connected between 1A and 1B
    and the second phase connected between 2A and 2B".
    Jan 2010
    2141
    Do your stepper motors just have 4 wires each?
    Do you have a multimeter that you could use to make resistance measurements of your stepper motor wires (in order to verify which pair of wires represents a single winding)?
    My inclination would be to treat 1a as a+ and 1b as a- (and similar for 2a as b+ and 2b as b-), but that's just a guess.
    Oct 2010
    Hi, did not see this reply, its sorted now but thanks anyway.
  1. Different ways of connecting the steppers to the driver. Help required
    By Kent_Norway in forum Stepper Motors / Drives
    Last Post: 11-18-2009, 09:46 AM
  2. CONNECTING BOB,DRIVERS AND MOTORS
    By BOBINETTE in forum CNC Machine Related Electronics
    Last Post: 09-07-2009, 03:53 PM
  3. Connecting two identical drivers to drive one stepper motor?
    By uplb in forum Stepper Motors / Drives
    Last Post: 11-24-2008, 04:13 PM
  4. Connecting 2 steppers in parallel
    By salvaCNC in forum CNC Wire Foam Cutter Machines
    Last Post: 09-29-2007, 12:42 AM
  5. connecting steppers
    By BAM in forum Gecko Drives
    Last Post: 01-23-2007, 12:06 AM
