Originally Posted by
hmc710
Will try using my Bobcad to com with the mach and see what happens. On my keypad screen the #9 does not seem to work. Is there a way to check this? The machine is an Acroloc M15 with the tool changer. In the work book it talks about using the M19 command, spindle stop & orientate, prior to raising the spindle and I can't get any command with a 9 in it to work. When I jog Z down it does pick up a tool and it orientates it back on the way up. Is the M19 used before every tool change?
Also paging through existing programs; On my OT control you enter the Oxxxx program number and arrow down key and it loads the program. The work book does not say how to load an existing program from memory. Tried input, arrow keys, etc and it stays on the same program. Any help here?
Thanks,
H
