585,719 active members*
4,547 visitors online*
Thread: DXF problems
    Jan 2011
    127
    DXF problems
    i need help fixing a problem i'm having in mach3.:tired:
    all the DXF files i load are too big for my table or are off set from the x0 & y0.
    IE - y-59 x-25 ..
    my table is in MM & is setup for x0 & y0, even if i set the X & Y to off set the -59 & -25 my table is not big enouth in the Y
    my limits are Y570 & x1460
    some are y640 but length is fine.. if i could change the X & Y temp to cut a DXF then set back to normal in Mach3
    the other issue i have is a tryed upping the Feed rate & got upto 200 & snapped a 2mm 2flute bit.
    I was trying to stop the MDF burning (4.75mm thick) have varied the speed from 3 - max (1 = 8000 max=20000 prm ) mini tool. have also run it at a feed of 30 & still burns. :withstupi
    any help out there ???? :stickpoke
    Open the .dxf files in a CAD program and scale/reposition them.
    As for the burning. If the bits not dull, you need to either use a faster feedrate, or lower rpm.
    Jul 2004
    72
    I can't help with the DXF, but a couple ideas about the burning.
    Are you cutting in one pass? Try two passes. You are probably not getting rid of the sawdust because flutes in that size of bit are really small. Try switching to an upcut spiral.
    Nov 2009
    93
    With tool burning issues, as stated previously limit the cut depth, use a carbide tool, make sure its spinning in the correct direction.
    You might also try blowing high pressure compressed air directly into the cut, it will cool the tool and get the sawdust out of the cut channel.
    May 2010
    I was suffering of burning issue for some time.
    In my case, it was because of low feed rate and higher spinddle RPM. It improved by a matched combination of feed rate and spinddle rpm.
    Try spinddle RPM 7000-8000 (for mdf) and feedrate about 50-70.
  1. G54,G55 problems
    By jeffm in forum Daewoo/Doosan
    Last Post: 11-11-2008, 12:37 PM
  2. PIC Problems
    By niwatori1 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-05-2008, 07:57 PM
  3. Big Problems
    By jeepcj776 in forum Commercial CNC Wood Routers
    Last Post: 03-30-2008, 09:06 PM
  4. Problems
    By vebers in forum Servo Drives
    Last Post: 05-03-2006, 05:59 AM
