585,906 active members*
3,912 visitors online*
Results 1 to 12 of 12
    Sep 2008
    66
    A2100 ALARM 39-73
    it's been 7 long months of waiting for "purse string holders", repair companies and couriers but, i was finally able to throw the power to our Arrow 500
    had Mike Kilroy hooked remotely to check settings on the BDS5 - he say's ALL GOOD
    did the align thing and tried a spindle command and got this error
    ALARM 39-73
    RUNOFF PATCHES INCORRECTLY SET
    Cause – The runoff patches are incorrectly set for the action you require
    Remedy – TOOL CHANGER set-up runoff patch required to operate the tool changer setup function
    SPINDLE SET-UP runoff patches required to operate the spindle alignment setup on machines with high torque spindles
    The machine will not be allowed to cycle while this patch is active
    Severity – 70 Still in cycle – Cycle start blocked
    any ideas what this might be?
    thanks in advance folks
    Mac
    Oct 2008
    123
    39-73
    hello it would appear that the run-off patches are set on.
    press MORE
    press SYSTEM CONFIGURATION
    press MACHINE APPLICATION ( just above middle left hand side )
    use the right arrow to move along untill you see a tab labelled RUNOFF.
    None of the boxes should have a tick in them. if there is remove the tick. commit the changes and that should be it.
    the security level should be set at service or above to make any changes.
    for security
    press MORE
    press SECURITY (top left)
    type in SERVICE then commit changes.
    any questions please e-mail
    regards
    mallardfizz
    Sep 2008
    66
    Quote Originally Posted by mallardfizz View Post
    press MORE
    for security
    press MORE
    regards
    mallardfizz
    YOU ARE STILL THE MAN MALLARDFIZZ!!
    that did it - i had a check in the spindle set-up box - my spindle now rotates
    thanks a bunch
    Mac:cheers:
    Sep 2010
    1765
    EXCELLENT!
    As usual, way to go Mallardfiz!
    Oct 2020
    Re: A2100 ALARM 39-73
    Can someone help me with ylthis issue?
    - - - Updated - - -
    Sep 2010
    1765
    Quote Originally Posted by Rolous View Post
    - - - Updated - - -
    Help you with WHAT?
    Mar 2011
    462
    If you are getting the same alarm as the original post, it should mean someone turned one of the runoff patches on and it needs to be turned off for the machine to function normally. There is a pretty good writeup from Mallardfizz on what to do already....If that didn't work for you you'll need to post additional information as to what you are dealing with.
    FYI: The runoff patches are a function to allow higher level setup of the machine that does not need to be done often. These modes take out safety features (like the interlock to prevent Z- moves from crashing into the ATC while it is at the spindle) so some machine functions get locked out when these are on.
    Mar 2022
    4
    hello, alarm 39-155: turret motor overload: appear on the screen but the input in the I/O Pware is (ON) ... any help??
    Lathe Hawk 200 with acramatic 2100, duplomatic 12 pos. turret
    Apr 2022
    Hello
    I have exactly the same problem but alarm number is different 39-58, but description is exactly the same . I have arrow 1000 with acramatic 2100 . I was trying to follow the instructions to resolve it but tab "runoff" is not there .
    Please help
    Mar 2008
    285
    Alarm: run-off patches are set on.
    press MORE>>
    type in CIMTROLUSA; Press ENTER; Password level changes to RUNOFF; then commit changes.
    use the right arrow to move TABS until you see a tab labelled RUNOFF.
    Set the security level to SERVICE. In Security type SERVICE; Press Enter; Password Level = SERVICE; Commit Changes
    Go to More>> SERVICE > Backup & Restore Machine Data: Defaults to 'Backup' > 'Machine Data' > Press Start Backup.
    Repeat this step again, and add an "a:/" in front of the filename below to make a copy for safe keeping on a floppy; or Network, or RS232 (Worth it's weight in GOLD!)
    Go back to MORE>>
    type in operator; Press ENTER; Password level changes to operator; then commit changes. You are finished.
    Now people can look; but not change parameters.
    Apr 2022
    Quote Originally Posted by gwood View Post
    press MORE>>
    Go back to MORE>>
    Thanks for your reply
    Unfortunately your password did not work for my machine but I fond the o e that worked .
    Operator for just looking
    Service for changing
    Worldclass for runoff patches
    Mar 2022
    4
    thamk you for your help !!!
  1. Replies: 6
    Last Post: 01-15-2019, 04:32 AM
  2. a2100 not enough ram error
    By msherman in forum Cincinnati CNC
    Last Post: 02-23-2013, 01:49 AM
  3. Arrow 500 with A2100 cnc
    By rai in forum Cincinnati CNC
    Last Post: 07-26-2011, 11:54 PM
  4. BDS5 with A2100
    By CHAD LAWSON in forum Cincinnati CNC
    Last Post: 03-15-2010, 02:16 PM
  5. help on how to use a2100 rap
    By bronco079 in forum Cincinnati CNC
    Last Post: 11-29-2009, 03:11 AM
