585,973 active members*
4,198 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > "abnormal coolant"???
    Aug 2010
    188
    hey all, i have an Okuma 852v mill that is controlled by a fanuc 31i. today neer the end of a drilling cycle i got this alarm: EX3019 COOLANT SUPPLY ABNORMAL. the coolant tanks are full of fresh coolant and everything seemed to be working fine up until a few min ago. i AM running a chip blaster thru spindle, and at the time it alarmed out i was runnning 500psi thru spindle. i am unable to find this alarm in any of my books and i am unable to reset it. any help would be great guys and gals. thanks in advance!
    Nov 2010
    Wink
    The float switch in the coolant tank is stuck in the down position. It may be buried in chips.
    Aug 2010
    188
    found some sort of breaker/relay in the back of the chip blaster that had tripped. re-set that and all seems to be working fine. could the float switch have tripped this??
  1. "motor steps per resolution" and "driver microstepping" settings
    By margni74 in forum LinuxCNC (formerly EMC2)
    Last Post: 10-24-2009, 08:33 AM
  2. "J" head type "millport"(tiwan,1980) clutch
    By marksbug in forum Bridgeport / Hardinge Mills
    Last Post: 08-17-2009, 04:48 PM
  3. Flood coolant wiring " NEED HELP PLEASE"
    By Gregory_C in forum Syil Products
    Last Post: 06-28-2008, 06:36 PM
  4. Replies: 0
    Last Post: 08-05-2007, 12:11 AM
  5. Bed stained from "coolant"
    By WilliamD in forum MetalWork Discussion
    Last Post: 02-07-2007, 12:27 PM
