586,005 active members*
5,034 visitors online*
IndustryArena Forum > CAM Software > Rhinocam > SELECTING MULTIPLE LETTERS IN RHINOCAM
    Jan 2011
    I am brand new to RhinoCam, I work in our school's workshop and am very inexperienced with our 3-axis CNC.
    I need to v-carve out a lot of text out of a sheet of mdf and am having to spend hours selecting each individual letter.
    Does anyone have a solution? What specifications should the font have? Is there no way to select multiple letters in a similar way I can select multiple regions?
    Thanks!
    ps If you have a solution, consider me the ultimate beginner, I would love step by step instructions on how to do this efficiently!
    Nov 2009
    30
    Multible Selection
    Hello
    i have faced this problem ,in rhinocam1 it was very easy by making a groub
    but it wont work in rhinocam2 so you have to make a new layer
    of all the text then
    go to rhinocam region selection tap and press select by layer button from selection button and choose the curves layer .
    another way is selecting the curves before creating procedure.
    Dec 2010
    problem cut level
    Hello all the world I am a beginner on rhino and I have a problem on rhinocam that I do not arrive has to resolve. For example.
    On rhinocam cut level z = -3 and on the g-code z = -13
    On rhinocam cut level z = -4 and on the g-code z = -14
    On rhinocam cut level z = -5 and on the g-code z = -15
    Note although all my works are in metrics.
    Thank you for answering me if he(it) please you
    Nov 2009
    30
    cut depth
    First thing you have to check if the draw is on the top c-plane on z zero
    you can look at it from the front screen
    if not check the cutting depth in cutting levels
    so if you want to cut 20mm depth each time 2mm it should look like :
    total cut depth : 20
    rough depth : 20
    rough depth/cut : 2
    Mar 2010
    99
    Quote Originally Posted by haron View Post
    Create MCS first and set it to south-west-top of stock
    I suggest you create MOP1, and set MCS in it
  1. Letters, Letters & Letters
    By Joe Crumley in forum Signmaking Topics
    Last Post: 11-20-2011, 03:46 AM
  2. dxf letters help
    By soundoffaudio in forum MetalWork Discussion
    Last Post: 01-12-2011, 06:07 PM
  3. RhinoCAM PRO
    By CAM USER in forum News Announcements
    Last Post: 09-07-2005, 10:05 PM
  4. RhinoCam
    By CarveJunky in forum Rhino 3D
    Last Post: 06-19-2005, 02:27 PM
  5. RhinoCam
    By Dogsione in forum Visual Mill
    Last Post: 01-26-2005, 06:09 AM
