585,758 active members*
4,280 visitors online*
IndustryArena Forum > MetalWorking Machines > Milltronics > executing a program with sub
    Mar 2007
    I have just been hired by a company to program and operate a milltronis mill with a centurion 5 controller.I do not have a book for it.I have written a easy loop program called o100 and it calls o200.
    m98 po200 l10
    this tells me program 200 does not exist.Any ideas what I am doing wrong?
    Which drive do i put the files in to run them. Any help would be appreciated.
    Oct 2009
    27
    Sub call
    If the file names are o0100 and o0200 the call statement M98 P200 L10 should work. Omit the "o" from the M98 line.
    Mar 2007
    thanks alot i will try it tommorow.
    Mar 2007
    Do I have to run the program out of the parts directory
    Aug 2005
    385
    If you want a quick way to check how to write the code, use the conversational programming boxes, write the a partial program like a "call" for instance and then open up that program in the text programming area.
    If this is confusing what I am trying to say, I will be back at the shop next week and I'll tell you the F key sequence to do this. It will basically write you sample code to show you the format you need to use when typing G code.
    EXIT 85 Manufacturing "The best custom wheels, period" (www.exit85.com)
    Experts in low volume, highly complicated, one-off forged aluminum wheels
  1. Mazatrol Program into a G Code Program
    By fuzzman in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 09-25-2012, 04:27 PM
  2. Replies: 0
    Last Post: 12-27-2010, 09:55 AM
  3. Replies: 12
    Last Post: 03-15-2010, 02:19 AM
  4. Whhat would be the best process for executing knife designs?
    By pesky_human in forum MetalWork Discussion
    Last Post: 11-13-2008, 04:52 AM
  5. Replies: 11
    Last Post: 10-09-2005, 05:45 AM
