I am an operator of above said machine in the title. The other night I was on a long run, everything was fine, program loaded perfectly at the start. Half way through the run I had to change over to complete a "hot re-work order". I go into edit mode, delete my current program, and upload the program for the re-work. I then went into the MDI and zero'ed my count, continued into auto memory mode, and ran the order out, no problems.
I then deleted the program and went back to MDI, reset my count to what it was where i left off, then went into Edit mode, typed in my program, followed the 07777 punch procedure, and when I pushed the "read" button, I got an error that said (rec) error.
The machine will run perfect manually typing in a full program, but will not accept a program, when this error occurs it sends a "corrupt" file back to the computer it recieves files from, complete jibberish is contained in them.
This is the first time anyone has seen this error. where do i start trouble shooting this?
