585,987 active members*
4,411 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Help! Need small CNC lathe with collet chuck
    Jan 2011
    I am a small manufacturer looking for a bench top CNC lathe with a collet chuck. I need this for cutting a small screw-like groove in plastic tubing. We cut about 12 different sizes with the diameter of the tubing running from .055" to .210" and with the length of the groove running from 4 1/2" to 8 1/2". I need the collets to hold the tubing firmly without marring the surface and would like to use a draw bar to facilitate production but I can't find any bench top lathes with a through hole large enough to accommodate a draw bar. Any suggestions would be greatly appreciated.
    Thanks! Ed
    Jul 2009
    219
    One thought,
    There is a company that sells 3j collets and manual closers on e-bay.
    those will fit in a 9x20 size lathe.
    Jan 2011
    Thanks for your reply. My original choice for a bench top lathe was the Tormach Duality lathe. It has 4.3" swing over saddle and 11.8" distance between centers with a .79" spindle through hole.
    I guess I'll have to get something bigger if I want collets and a closer.
    Oct 2009
    118
    LittleMachineShop.com - Collet Chuck for ER-32 Collets
    This is a good collet system for the mini-lathe.
    If you buy a nut you could make it.
  1. Anyone us the Haas 5c collet chuck?
    By shawncnelson in forum Haas Lathes
    Last Post: 09-17-2009, 08:52 PM
  2. Online ordering power chuck, collet chuck, MC vises form Taiwan
    By mtadirect in forum News Announcements
    Last Post: 08-30-2009, 03:37 AM
  3. What collet chuck is this
    By irving2008 in forum MetalWork Discussion
    Last Post: 11-20-2008, 10:05 PM
  4. Air collet chuck for a c3?
    By gazmalman in forum Mini Lathe
    Last Post: 06-16-2008, 12:23 AM
  5. Which collet chuck?
    By Al_The_Man in forum Uncategorised MetalWorking Machines
    Last Post: 06-27-2004, 07:11 AM
