Originally Posted by
pinguS
Hi all
Just wondering if there is such a thing, which lets you state the taper amount on the machine control.
I currently have a 18t control, and as my machine is moving towards the spindle, the axis tapers down slightly, so when cutting the diameter reduces towards the spindle.
Can this be adjusted in any sort of parameter, normally ok if taper is about 0.02mm as I can just make adjustment in the program, but now after a slight smash, the taper over 100mm in Z towards the spindle has about 0.25mm down in X, and when doing complex parts, its too much to adjust the whole program.
Basically looking to see if a parameter is available to allow compensation, or am I better off calling an engineer take apart and fix the machine?
cheers for any help....
pinguS
