Well I've run into my first problem with the j325. Today I went to turn it on and nothing happened at the controller. I could hear the normal noises coming from the back cabinet when I turned on the main power switch, but nothing happened when I turned on the controller. I switched it all of and tried again and it turned on fine. So I shut it back down while I waited for the compresser to fill up, then turned off the compressor and tried turning the tree bask on and the same thing happened. Power at the back cabinet, but the controller wasnt coming on. I could tell that the monitor was coming on, but that was about it. I tried actuating the tool clamp and nothing. I tried pressing the reset button to see if the servos enabled but nothing. This machine is powered with a phase adder, but it hasn't seemed to be an issue. Any ideas?
