585,914 active members*
3,839 visitors online*
Results 1 to 3 of 3
    Jan 2011
    Tool Change Problem
    I have a problem with a chinese made milling center Gold Sun GS1060.
    The machine was made in China but has a Mitsubishi Meldas 60S Series controller and there is no information available.
    I've found handbooks of the Mitsubishi controller, but nothing about the GS1060 machine.
    The problem is:
    When I send the command M06, in MDI mode, to change tool, the magazine, becames jammed and the machine stops.
    It seems the Z position of spindle is not aligned with the tool magazine.
    Is there any procedure to calibrate the Z position of the spindle relative to tool magazine?
    Thanks,
    Roger
    Jun 2008
    150
    Not familiar with the Meldas 60, but you would think there would be a 2nd Home or Number 2 Zero position for Z axis. Should be a Machine Constant Parameter that probably is listed in the Machine nomenclature and maybe a common parameter for the Meldas 60. Or could it be that the magazine is of the carosel(sic) type and has to be moved to the Z axis position mechanically? As a matter of fact, I'm not familiar with the machine model either! Maybe I don't know anything!
    Later,
    Lee
    Aug 2009
    71
    Need Help! Tool Change Problem
    Normally on M60 control below parameters are used.
    1) #2038 ( #2_rfp) of Z-axis, for the 2nd reference position of Z-axis. The unit is in mm i.e. xxx.yyy mm
    2) #3207 (SP007, OPST) of Spindle 1, for the Spindle Orient position shift.
    The count 4096 corresponds to 360 deg i.e. 11~12 counts for 1 deg. However it is so for the standard 1024 PPR encoder, will be different if any other encoder is interfaced.
    The above ones are basic parameters which you can try. However some MTBs, put additional interlocks with Position Switches / R parameters, to set the hi/lo limits for above parameter values. In these cases, we need to go through PLC to check the same.
    Best Regards,
    Girish
  1. TOOL CHANGE PROBLEM
    By Stebedeff in forum Fanuc
    Last Post: 03-18-2009, 02:23 PM
  2. Tool Change problem
    By mattpatt in forum Fanuc
    Last Post: 03-10-2009, 02:05 PM
  3. Need Help With Tool Change Problem
    By AZDEN in forum Fanuc
    Last Post: 11-21-2007, 08:44 PM
  4. Problem in Tool change
    By ahmedsamy_81 in forum G-Code Programing
    Last Post: 02-14-2007, 04:02 AM
  5. Problem in tool change
    By ahmedsamy_81 in forum Uncategorised MetalWorking Machines
    Last Post: 11-06-2005, 11:14 PM
