Hi guys, long time member, first post.
I bought a used Prolight 1000 CNC and have retrofitted all of the electronics to use a Gecko 540 and Mach3. Works great so far.
I need to do some work on the spindle but i am unsure how to take apart the draw bar and pulley any farther. If i put a wrench on the draw bar bolt and turn clock wise, it turns for several turns as the draw bar spring is tightened and the washers shown tighten together. If I turn it in the other direction, it turns for a couple of turns and seems to hit a very hard limit.
As you can see, i have loosened the nut holding the pulley and the set screw. The pulley will turn a fraction on the threaded shaft.
Basically, what i am asking is, how do i proceed to take this apart. Are there any difficulties once done to reassemble it?
Thanks!
Bob
