585,670 active members*
4,263 visitors online*
    Nov 2010
    Exclamation Fanuc 6M Controller
    Guy's,
    I need your help again. A few questions.
    1. How do you use the little letters on the controller keyboard, example..key R has a small c, but when I hit the button R is all I get?
    2. What are Offset 1-99 used for?
    3. What are Work offsets 00-06 used for?
    4. What are H offsets, and D offsets used for?
    I know this is allot, I appriciate any help on this. Thanks,
    Sep 2010
    1230
    Quote Originally Posted by QUALMACH1 View Post
    Guy's,
    1. Not all of these characters are accessible on all controls, it depends on what options the control has. However, if your control can access these characters, you should have a key labeled Shift. Press that and then the Key with the required second character.
    2. These are tool geometry (length and diameter). There will be more offsets available than tools. There will come an occasion when for what ever reason, two offsets will be applied to the same tool. For example, the top and bottom face of a Side and Face cutter, slitting saw etc.
    3. These are Work Offsets and are called in the program by G54(1) through to G59(6). They are used to set the Zero point in X,Y, and Z of the workpiece.
    4. H offsets are used for tool length, and D offsets are used for tool radius offsets, used in cutter radius compensation. Many machines only had one set of offsets and H and D values had to come out of that one registry.
    Its good practice to use an offset number the same as the tool number for the H command in the program when applying the tool length offset. On machines that only have one offset registry, that is, no separate H and D registry, I try and use an offset number that has some significance to the tool number for the D offset if its used. Lets say that T02 is being used, and cutter rad comp will be applied. The H offset would be H02, then I would use an offset well above the maximum tool capacity of the machine for the D offset. Lest say the max number of tools is 30, I would start at 51 for the D offset for T01 and in the case of this example, D52 for T02. Controls with both H and D offset registries, you just use H1, D1 etc for length and radius offsets for each tool.
    Regards,
    Bill
    Nov 2010
    I appriciate all your help. Thanks,
  1. Replies: 5
    Last Post: 03-09-2011, 04:11 PM
  2. fanuc 6t controller
    By stlwrksdesign in forum Fanuc
    Last Post: 03-08-2011, 04:02 PM
  3. Fanuc OT controller
    By kantaras in forum Mastercam
    Last Post: 11-22-2010, 01:48 AM
  4. Fanuc 15m controller
    By bigfoot in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 12-03-2009, 05:20 AM
  5. Fanuc controller
    By royt in forum Want To Buy...Need help!
    Last Post: 06-02-2008, 04:47 PM
