586,009 active members*
5,100 visitors online*
IndustryArena Forum > Other Machines > CNC Wire Foam Cutter Machines > dxf to g-code ad-hoc _wire cutting_
    Feb 2009
    there are many topics about soft that can turn dxf to g-code, but all of them are useless for wire cutting. i'm using now dxf2gcode, but i have to correct the output gcode very hard (very!). other soft makes convertion dxf->gcode even worse. so i'd like to ask what soft use people that actually cut foam with wire in 2D. method - 2 drives for each axis, foam block simply lays on a table. operating system does not matter but it would be better linux.
    no suggestions from metal/laser and other non-foam cutters please i know how to mill other materials.
    Feb 2007
    412
    Have a look at Dolphin PartMaster.
    The Wire EDM will produce what you need, it has 2 and full 4 axis capabilities.
    www.dolphincadcam.com
    ATB
    Andre
    Jul 2007
    15
    foamworks 4.0 will do what you want. I am currently in beta testers pool - stay tuned for the release date. Looks pretty cool so far
    Feb 2009
    well, 1000IPM, i didn't see any possibility to import *.dxf.
    Jul 2007
    15
    in Foamworks 3.0 - you created in Cadworks - saved a .dat file - then brought that into Foamworks. With the new version of Foamworks 4.0 - direct dxf importing is available. I am doing it now. Works well.
  1. Replies: 4
    Last Post: 03-29-2011, 02:39 PM
  2. Converting Fanuc G code to Seimens 840D G code
    By Jasbinder in forum SIEMENS -> Sinumerik 802D/808D/810D/828D/840D
    Last Post: 02-20-2011, 05:02 PM
  3. Replies: 8
    Last Post: 12-15-2010, 09:32 PM
  4. G-Code viewing source code
    By Hussam in forum Visual Basic
    Last Post: 03-15-2009, 06:15 PM
