Hi folks,
I'm working on a '86 Daewoo Puma 10 turning center, the only CNC in our shop. I'm the only person that runs it. We bought it used about 4 years ago. Up 'till now it's been doing well for us. We machine smallish parts mainly from DOM tubing up to 2-3/8 OD with some basic operations. We also machine parts from 4140 HR 2" shaft. We only do about 20 different parts over and over and are fairly low volume (averaging maybe 50 or so parts of each variety every 2 months if you need an idea), and they aren't any more than 6" long that we put through this machine (part stick-out from the chuck), and never had to use the tail stock before.
It has started to develop some diametral inconsistancies and now some severe chatter , without changing the programs, offsets, RPM, or feed. From the inconsistancies to the now severe chatter, the time span has been rapid, about 15 hours in working time. By "severe", I mean it doesn't produce a good part, the chatter won't go away by decreasing the RPM, or by either reducing or increasing the feed rate.
I've made sure all the tools in the turret are still tight, new inserts, greased the chuck again, and made sure the chucking pressure didn't change. I'm out of ideas.
I fear that either the main spindle bearings or the ways are wearing on the axes.
Does anybody have any ideas? Are there any adjusments on tightening the main spindle bearings? How do I adjust the tapered gibs in the ways?
The parts book and manual don't explain this very well, and doesn't mention at all adjustment of the spindle bearings.
Thanks in advance,
Dan
