cant find a way to get this wright , just want to do a profilearound the edge like a router
Is there no one that can help
I'm very new at this, but I would do the following:
Activate 2D sketch and choose the sketch plane to be the plane that the bottom edge of the is in. Define your profile using the b-spline tool, or whatever, to get a smooth line. Double to line somehow. Make sure the outer of the doubled lines is outside any of the waste of the cut. Then use extrude cut to cut the edge of the top, selecting the doubled lines to extrude.
I tested this using circles instead of splines, and it worked.
Couple of pics attached.
You need to join the forum on Alibre's website.
There are some highly skilled users there.
Alibre Design User Groups • Index page
Joe
I got it closer i will post it when I get it done I had to select one edge at a time and had to put a radius on corners to make work better
