585,906 active members*
4,004 visitors online*
IndustryArena Forum > CAM Software > SprutCAM > Work piece size?
    Aug 2009
    42
    Work piece size?
    There's probably an obvious answer to this but is there a simple way to determine the size of a work piece without having to resort to using the measuring tool?
    e.g. if I have a complex part and add stocks to it, is there somewhere that will give the X,Y,Z size of the resultant work piece?
    Christian
    Mar 2009
    50
    Christian, the best way that I have found to do this, is to use the 2D Geometry function. Turn the geometry model off, and then choose a line or a point. Then click on the corner of your workpiece and read the values in the axis dro on the left of the screen. I know this isn't ideal, however it is the best way that I have found.
    Nov 2005
    145
    Christian,
    This might be what you're looking for:
    1) Go to the Model tab and select your part or workpiece or whatever.
    2) There is a little-noticed toolbar just below the main toolbar in the upper left-hand corner. The third icon from the left is the "set properties of the selected objects". Click this icon and it will give you the min, max and size along the three axes of the object you selected.
    Hope this helps,
    Terry
    Aug 2009
    42
    Hello Terry,
    Thanks that's exactly what I was looking for. Thanks.
    Regards, Christian
  1. z axis work piece offset
    By The CNC Noob in forum Haas Mills
    Last Post: 08-05-2009, 12:18 AM
  2. General CAM question regarding work piece
    By radioactive in forum Uncategorised CAM Discussion
    Last Post: 04-24-2009, 01:08 PM
  3. Cutting a work piece.
    By alexccmeister in forum MetalWork Discussion
    Last Post: 03-20-2007, 07:02 AM
  4. RFQ: Lathe work, one piece.
    By SCCoupe in forum Employment Opportunity
    Last Post: 07-24-2006, 11:58 AM
  5. RFQ for Two Piece Lathe & Mill Work
    By stang5197 in forum Employment Opportunity
    Last Post: 02-21-2006, 04:17 AM
