Handling Precautions
1. The large bearings grease seal, please use as they are.
Large sealed bearings are not lubricated Gu Su Su 1, which is also fine to use it in situ, grease rust before Me-hee coarse vertical (or oil) and iron powder not 混大 to eliminate waste O 觔 Meshimasu to be washed with white 淸浄 kerosene.
2) to bring harmful results caused the wound shock and stroke in the orbital plane of the bearing during assembly, please be careful, especially dealing.
3) sign indicates radial runout of poetry place 般大 way or chamfer the inside and outside the ring E (or O) 埸合 殳 mount on the shaft axis in the visible, this E (or 0), wet place Me the. resultant plants together and place your going to be the opposite position 镢 up correctly and eccentricity of the axis: ^ Please. The outer 叫絵 places including the eccentric position of the box 较大 铀受! Sign of the outer ring and E (or 0) As mentioned I made the mounting position of the opposition will correctly position the whistle.
