585,931 active members*
3,646 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > High Speed Spindle for SIEG X2 Mill - getting technical
Page 1 of 9 123
Results 1 to 20 of 174
    Jun 2005
    36
    High speed spindles are complicated and pricy, as I've learned. KDN Tool & Automation Engineering will provide a belt drive for my MicroMark MicroLux #82710. KDN Tool & Automation (www.kdntool.com) is in the process of converting my mill to full CNC. The SIEG X2 can get up to 2,500 rpm with the stock gear drive. KDN Tool & Automation has an option, to belt drive the spindle, getting it up to 4,000 rpm. Going higher is not recommended.
    I am not recommending that anyone do what follows!!! I'm only brainstorming.
    You could purchase a Proxxon Micro Mill MF 70, from Tool-Switch for $300 + shipping and taxes. The Proxxon motor and spindle assembly, turns from 5,000 to 20,000 rpm. Proxxon is a quality made machine. The application for the MF 70 is "Small precision mill for lab, optician, jewelry, electronic, and model projects". I want to engrave. The maximum power is 100watts. So lets see if the Proxxon motor and spindle assembly can be adapted for engraving. Back of the envelope scoping calculations. I worked as an advanced development engineer up to 20 years ago. I switched to planning, marketing, and sales management - it paid a lot better. So I'm rusty on my Manufacturing Engineering (did that before becoming a Mechanical Engineer) -please feel free to correct me in my calculations.
    Torque (N-m)=depth of cut (mm) X width of cut (mm) X feed rate (mm per tooth) X number of teeth X machineability factor (0.145 for aluminum, 0.435 for steel)
    depth of cut (mm) 1 mm 0.039 in
    width of cut (mm) 1 mm
    feed rate (mm per tooth) 0.18 mm/tooth high speed steel cutter, on brass
    number of teeth 2 a pointed engraving cutter
    machineability factor 0.29 half way between aluminum and steel
    Torque (N-m) 0.104 N-m (ref: one N-m = 0.74 foot-pound)
    Next determine the torque of the Proxxon MF 70 spindle, assuming a constant power of 100 watts. (Who knows what the torque speed curve is)
    Torque (N-m) = [Power (kw) X 9,550] /rpm
    Power (kw) 0.1 0.1 0.1 0.1
    rpm 20,000 15,000 10,000 5,000
    Torque (N-m) 0.048 0.064 0.096 0.191
    It looks like maybe somewhere between 5,000 and 10,000 rpm it might work, but not knowing the torque speed curve for the Proxxon MF 70 motor, it's only a guess. Well it was only an idea.
    Lets look at price points for "high speed spindles"
    Sherline (from DiscountCampus.com)
    #33050 High Torque DC Motor & S/C Assembly $210 discount to $194.25
    #33060 DC Motor & Headstock Assembly W-S/C $312 discount to $288.60
    #33070 10,000 RPM Headstock, Motor and $402 discount to $371.85
    Speed Controll Unit
    Taig
    #200-55CR Spindle Motor (1/4 hp, 3,400 rpm $110
    Continous Duty
    High end engraving machine spindles (I don't know if the price includes motor)
    Spindle unit High-torque spindle unit 3,000 - 12,000 rpm
    High-speed spindle unit 5,000 - 20,000 rpm
    High-torque milling spindle $800
    High-precision milling spindle $1,800
    High-speed engraving spindle $1,700
    Specialized 50,000 rpm "engraving" spindle and motor $5,000
    Now, the article "High Speed Spindle Design and Construction" Engineering Research Center for Net Shape Manufacturing - The Ohio State University - by William Popoli, President, IBAG North America - on the web site MMS Online (http://www.mmsonline.com/articles/hsm9802.html) shows that amongst the many critical factors, the bearings play an important role. The article developes the knowledge required to select proper bearings.
    Now I've got a spindle that came with the machine. What if Little Machine Shop were to develop replacement spindle bearings, good for 30,000 rpm, continuous duty, permanently lubricated, no forced water or air cooling. That were pressed into a SIEG X2 spindle casting (will need ceramic balls and specific design criteria for selection of the proper bearing, and don't want to brinell the raceways or crush the ceramic balls when pressing them into the casting and on to the spindle). So a shop needs to do this (tooling).
    Now we can turn the $549.79 (including shipping) MicroMark MicroLux milling machine #82573 into a 30,000 rpm mill for the price of a few bearings. If you want to try this yourself Boca Bearing sells bearings one at a time (www.bocabearings.com). They may even work with you to develop a selection for your parameters.
    But where's the motor? Good question. In all my searching there is very little out there about high speed spindle motors. In this day and age there must be all kinds of candidates out there. I'm not an Electrical Engineer, so is there anyone out there that can help? Assuming the formulas for spindle torque are correct, what is needed is a motor (not an air motor - too noisy) that can be controlled, continuous duty cycle (some "engraving" jobs could take 24 hours non stop), self cooling, and can run at 30,000 rpm and deliver quiet, reliable, smooth Torque.
    Just brain storming, why can't a dc servo motor be used?
    Whelen
    Aug 2004
    115
    Quote Originally Posted by whelen
    and can run at 30,000 rpm and deliver quiet, reliable, smooth Torque.Whelen
    Nice article.
    I would use an overly powerful, slower electric motor running through belts and cogs or pulleys to get the speed. Quieter, cooler and easier on the wallet. JRouche
    Jul 2005
    9
    maybe you're not the only one ...
    who thinks the proxxon motor would work. If you look closely down the page here http://www.flashcutcnc.com/html/mach_acc.html#8000 you'll notice what appears to me at least to be a Proxxon motor repackaged as a high speed spindle. It doesn't have the same packaging as the micromill you've mentioned if you look at the Toolswitch site -however- the same motor is used in the handheld at Toolswitch - see http://www.toolswitch.com/prx-us-38481.php and as well the Proxxon micro mill sold here in Japan has the same yellow green motor housing with slightly different ratings (we're 100v/50hz here).
    I'd be interested in hearing the Flashcut price for that spindle hehehe...
    -tokyocrow
    Jun 2005
    36
    Tokyocrow, youre right. Here is the pricing. Thanks for the great information.
    Whelen
    http://www.flashcutcnc.com/html/ord_price.html
    Accessories for the 8000 Series Mills
    NF-PM-148-211, NF-PM-148-275, NF-PM-148-952, NF-PM-148-260
    Spindles / Dispensers
    NF-PM-148-211 Spindle 100 W; 5,000-20,000 RPM; 1/8" Collet; Mechanical Height Compensation
    NF-PM-148-275 Spindle 150 W; 5,000-60,000 RPM; 1/8" Collet; Automatic Height Compensation
    NF-PM-148-952 Dispenser for liquids, grease, oil, paste, silicon, glue, sealant, paint, etc.
    NF-PM-420-003-0500 Spindle 500 W; 11.000 - 25.000 RPM
    NF-PM-239-110 Collet set .039" to 1/4" (14 pieces)
    NF-PM-239-120 Collet set 3 to 8 mm (7 pieces)
    NF-PM-148 991 4000 Spindle 500 W; 300 - 24000 rpm; 1/4- or 1/8 inch Collet; Tool changing system with length measuring sensor.
    Part Number Description Price Spindles / Dispensers
    NF-PM-148-211 Spindle 100 W; 5,000-20,000 RPM; 1/8" Collet; Mechanical Height Compensation $345
    NF-PM-420-003-0500 Spindle 500 W; 11,000 - 25,000 RPM; ¼" and 1/8" Collets $495
    NF-TI-6990 600 Watt 8000-24,000 RPM; ¼", 1/8" and 6mm (.236”) collets $545
    NF-TI-2311 600 Watt 80-2500 RPM; 3/8", ¼", 1/8" collets, accepts other ER16 Collets $1,295
    NF-PM-148-275 Spindle 150 W; 5,000-60,000 RPM; 1/8" Collet; Automatic Height Compensation (Floating Head for Engraving) $2,995
    NF-PM-148 991 4000 Spindle 500 W; 300 - 24000 rpm; 1/4- or 1/8 inch Collet; Tool changing system with length measuring sensor. $4,995
    NF-PM-239-110 Collet set .039" to ¼" (14 pieces) $295
    NF-PM-239-120 Collet set 3 to 8 mm (7 pieces) $265
    Proxxon Hand Held Rotary Tool IB/E (Looks like the Flashcut NF-PM-148-211 for $345)
    Price: $ 105.00
    This high-revving motor has full-wave electronic speed control capable of producing continuously variable speeds between 5,000 and 20,000 rpm and is usable for extended periods at a time. The ground steel spindle runs in a ball bearing assembly, minimizing play. Six high concentricity collets sized 1/32 in., 1/16 in., 5/64 in., 3/32 in., 7/64 in., and 1/8 in. (1.0, 1.5, 2.0, 2.4, 3.0 and 3.2 mm) along with a collet nut are included.
    MICROMOT steel collets are hardened and thus have a high, consistent flexibility. They also maintain prolonged accuracy, even after regular use. The triple-slit collet is substantially more difficult to manufacture than the four-slit type, but offers a better load-bearing surface. This is especially important for cutters with small shank diameters. These collets should not be compared with unhardened, four-slit collets of brass and aluminum.
    Features
    · Ball bearing spindle of ground steel, with lock button for rapid cutter changing.
    · Streamlined die-cast aluminum head for exact bearing seats and optimal stability.
    · Quiet, powerful 100 W motor with full-wave electronics for continuously variable speeds between 5,000 and 20,000 rpm.
    · Complete with six triple-slit steel collets covering 1/32 in. to 1/8 in. (1.0 - 3.2 mm).
    · Packed in durable plastic case, complete with the 34 bits & cutters as shown above.
    Package
    · Rotary Tool IB/E
    · Six triple-slit steel collets covering 1/32 in. to 1/8 in. (1.0 - 3.2 mm).
    · Durable plastic case
    · 34 bits and cutters
    Technical Data
    · Speed: Variable (5,000 - 20,000 rpm)
    · Volts: 110-120V AC, 60 Hz
    · Max Power: 100 W
    · Length: 9 in.
    · Weight: 1.1 lbs
    Jun 2005
    36
    JRouche, thanks for the idea. Turns out that is what KDN Tool & Automation Engineering Co. is doing for me right now, as a part of their CNC retrofit to my SIEG X2 MicroMark MicroLux Milling Machine #82573. They know the capabilities of the X2 milling machine motor, and spindle bearings, and are implementing for me a belt drive conversion (nothing new, Little Machine Shop has such a conversion kit). But it seems that a spindle speed higher than 4,000 RPM is possible with other modifications to motor and spindle configuration. Which they are implementing.
    Again thanks for the indormation.
    Whelen
    Feb 2005
    750
    Wow, the specs on that Proxxon are impressive! Just all those colletts are worth having! And the price is great too.
    (The oppinions above are the authors and do not represent those of CNCZone or its management.)
    Halfnutz
    Jul 2005
    9
    Whelen,
    An option not mentioned yet ... just to throw it in the pot. Take a look at this beauty - it'll remind you of your last trip to the dentist!!
    http://www.cncmasters.com/accessorie...g%20attachment
    There's a lot of drawbacks to air driven in general but 40,000 revs via an induction motor regardless of gears, belts or direct drive would have its own unique set of issues to deal with too.
    --TC
    Jun 2003
    1365
    I havent been able to read this entire post, but heres something that needs considering,
    What max feed rates can you run? can you still take a decent chipload or will you just be burning?
    At 30k your gonna need to be cutting at over 100ipm.(I didnt do the math, just a good estimate)
    Jon
    Feb 2005
    750
    I have a 55,000 RPM air driven pencil grinder (from Harbor freight for 16.00 on sale) that fits into a 5/8" R8 collet with a tubular drawbar to feed the air supply. The TIR on mine is not good, but there are other more expensive models available. I saw the set-up somewhere and decided to try it out, and I'm in the process of making the hollow drawbar (god, I forgot all about that project). Its a neet way of getting an 1/8" bit to go 50,000 RPM on a mill, but I dont know how well the set up will work yet. Heres a copy of the link I got the idea from.
    http://www.homemetalshopclub.org/new...eb04.html#mill
    (The above oppinions are the authors and do not represent those of CNCZone or its management.)
    Halfnutz
    Jul 2005
    9
    Jon,
    Hmmmmmmm. I had to stop and think about this for a bit. I routinely use a 30000 rev handheld for sculpting aluminum (JIS H 4100). At first thought you think "hey if can do it manually at 30000 than why can't a machine do it slowly at 40000?" ---but-- when I visualized the motion I make with the tool its probably very high rate strokes indeed although I doubt it would approach 100ipm. I think based on his previous posts Whelen is wanting an precision engraving/relief sculpting rig. Much the same as I am trying to figure out. I would assume he will be using tiny ball mill ends with 1/8th collet and not taking more than a few 1000ths at a time with thousands of passes thus chipload and feedrate would not be such a problem although maybe not in theory optimal for CNC in a machinist's context. As I'm new to CNC I think I'm missing something here though so anything you might have to add would be highly appreciated - I'm looking for a tool similar to Whelen's though with more workspace.
    --TC
    Jun 2003
    1365
    its not the speed you move it, its the speed it needs to be moved. if its rigid, you should be taking around .0005-.0008" per flute,
    Any carbide has a suggested chip load, if you dont get that chip load, it will die prematurely, good luck running hss that fast
    Jon
    Jul 2005
    9
    Jon,
    Thanks for the info. I've obviously have a lot to learn hehehe. Is there some type of chart to read and calculate these ?
    BTW right now I'm using CVD diamond tipped tools on 2mm (approx 1/8th inch) shanks - mostly ball shaped with no real flutes (more like a burr). I quit using anything but diamond because as you indicated they burn up too quickly. When and -if- I do get a mill I'll probably continue to use diamond though not CVD exclusively. Every bit I've bought in diamond I still have and use - even on green porcelain and sometimes on an occasional screwup I use them on bisque porcelain which is about like a grindstone to any tool. As a note for some reason in the U.S. diamond tools cost about 2x the price here in Japan.
    --TC
    Jul 2005
    9
    Whelen,
    I took a much closer look at the Proxxon motor(s) today when I was in the tool shop. I don't think they'd do so well after all - the cont rated duty cycle for the best Proxxon motors including the one Flashcut is using is 30 mins max. That was for 100v, 110v, 220v, and both 50/60hz.
    --TC
    Jun 2005
    36
    Tokyocrow
    I looked into the CNCMasters idea you suggested. It looks like a router solution. Also I've continued researching "high speed spindles". They can be deadly. At speeds even as low as 2,000 rpm a broken bit or loosening collet can cause a lot of damage. Of course safety glasses are mandatory. I prefer a face shield. But what about the rest of the body. At high spindle speeds the flying bit becomes a projectile and can kill. By the way I'm not coming down on your idea. It's just the reading I've done has alerted me to the safety issue of high speed spindles. I've always wondered why engraving machines are enclosed in a "bullet proof" box. Well now I know. I'll be encasing my "engraving" mill within a "bullet proof" box. The articles I've read say that conventional engineered tool holding forces are NOT sufficient to hold "bits" at high spindle speeds. Using a technology engineered to cut wood for cutting metal is a very serious risk. Tokyocrow, thanks for your ideas.
    Whelen
    Jun 2005
    36
    Halfnutz, I've looked into the air motor approach to high speed spindles. It looks like a great idea. To generate the CFM (cubic feet per minute) air flow for the required torque, a good size air compressor is required. And the noise level of the air motor is very high. Economical solution but noisy.
    Whelen
    Jun 2005
    36
    Tokyocrow and Jon, you are right, an "engraving" tool is removing very little material, so high speeds can be used and still be within the chip load requirements of the tool. Yes carbide burs can be used for a roughing tool path which leaves material for a finishing "cut" with the engraving tool. The Designs Computed, Virtual Sculptor VS3D/VScad3 software allows you to design (CAD) in raster space and converts to vector space. It generates the tool path (CAM), and can rough cut and finish cut by allowing the precise specification of the cutting tool geometry(s).
    As far as watts of power to do high speed engraving/sculpting/burnishing - the company to emulate is Roland. A leading Japaneese digital CNC engraving machine manufacturer. They have a machine for every price point. I'm trying to emulate the MDX-500. It comes with a high-torque spindle unit, 3,000 to 12,000 rpm or a high-speed spindle unit, 5,000 to 20,000 rpm. The spindle motor is dc brushless, 400 watts when with the high-torque spindle. So this gives an idea of the power required for a high speed engraving spindle. Tokyocrow, you were right in concluding that the Proxxon micro mill was under powered. My calculations also seemed to indicate that.
    Also to repeat, these high speed spindle engravers are housed in a protective transparent box. A broken bit or loosened collet can cause a disaster.
    Our conversations are interesting as they are similar to what we did in the concept phase, when I worked as an advanced development engineer 20 years ago.
    By the way KDN Tool & Automation Engineering ( www.kdntool.com ) is studying a concept to get my stock SIEG X2 2,500 rpm bench mill to 9,600 rpm for engraving. They are interested in solutions as well as CNC conversions, and will work with you to get you to your application objectives.
    Whelen
    Feb 2005
    750
    Whelan, Its definately a once in a while deal, not something for heavy use. I geusse the best use for it is pc board drilling, I've got a set of drill bits so tiny it's unbelievable, Ive tried using them with a 1/8" R8 collet at 2500 RPM and its too slow, they stick and break.
    But yeah, for less than 20 bucks its a nice little tool to have in the shop, I use the little grinder for all kinds of stuff. Its easier to hold than a dremel, and at those speeds it makes a difference.
    Halfnutz
    Jul 2005
    9
    Whelen,
    High Speed Spindle Safety is not really a concern for me as my wife makes sure I'm bound in leather, goggled, and plugged when I play - A full face shield would be a bit cumbersome though and detract from the pleasure as I couldn't see so well for closeup RCH work!! On the serious side though you're darn right about safety issues and I've seen less mention of it within CNCzone (why isn't there a safety forum?) and any other site as well, also lots of evidence (photos and videos) its a passive subject (as commonly the case everywhere) though it shouldn't be. BTW whatever CNC machine I wind up building/buying will be inside a 2cm thick composited granite enclosure with brushed alum frame and plexan portals and loads of exceptionally bright LED lighting. I have to admit though its actually less about safety and more about noise abatement and style (kind of cool design ain't it?) - we live in a Tokyo apartment where the expectations and tolerance of noise is quite low in comparison to the U.S. thus the heavy stone.
    Engraving .... high speeds ... what a confliction eh? Arrrgghh! I've gone around full circle on high speed spindles. The machine I've pretty much decided to buy has a 220v 0-7500rpm VFD driven spindle (2HP). For some of the work I do however I'll have to go a lot faster. My current handheld runs at 35,000 and does a pretty good job. The problem for my work is that CNC at our ¥/$ level doesn't have any means to measure torque nor provide smart feedback to control how fast the tool takes a bite thus I think I'll need 40,000~50,000 with a light bite, slow feed rate, and plenty of experientiamentanation <as W would put it>. I know very little about feedrates, chiploads, cooling etc etc. and that somewhat frightens the analytical controlled process engineering side of my brain, however I keep on the right side of my brain the knowledge that shops all over Bangkok finish and engrave work for folks like Cartier and Harry Winston with about the same level of knowledge as I have using an accurately driven CNC mounted 50,000rpm tool that curiously has the same part number as a dental drill when sold in Japan.
    Enough babbling ... my handheld's manufacturer recently introduced a new handpiece which I've been drooling over, now I've convinced myself that its the candidate for hanging on the CNC machine I eventually will get ... albeit its low torque compared to an air driven beast but a lot quieter. There's a lot of theory to shoot it down here in the forum but I'll make it work somehow the same as the guys in Bangkok do!! Take a look ... http://www.saeshin.com/new%20products.htm .. peek at the Forte 100. Not a lot of info on the English side but I'll pick one up when I'm in Seoul later this month. They also make a fine line of natural diamond burrs and toolends I swear by now.
    --TC
    Jun 2005
    36
    Tokyocrow, here are some speeds and feeds referances.
    #1 http://www.gatewaycoalition.org/file..._Machining.ppt
    #2 http://www.niagaracutter.com/techinf...ook/speedfeed/
    Here is information on High Speed Machining
    #3 Basic Math For Ball Nose Tools
    #3 http://www.mmsonline.com/articles/1103rt3.html
    #4 Lending a Hand to the Handbook
    #4 http://www.mmsonline.com/articles/080309.html
    #5 Industrial Engraving
    #5 http://www.mmsonline.com/articles/1102bp2.html
    #6 Four Tool Holder Quality Factors
    #6 http://www.mmsonline.com/articles/119804.html
    #7 What is High Speed Machining
    #7 http://www.cnczone.com/forums/showthread.php?t=462
    #8 Even slow spindle speeds can throw a dangerous projectile
    #8 Safety at High Spindle Speeds
    #8 http://www.mmsonline.com/articles/hsmdm/cut6a.html
    Hope this helps.
    Whelen
    Jun 2005
    36
    To the people that have responded to my post. As I've mentioned, I finally realized that "high speed spindles" are a subset of "high speed machining". And that "feeds and speeds" have changed dramatically due to the advances made in "high speed machining" technology. I'd like to share some of the information I have found during my web searches on the topics: high speed machining, feeds and speeds, end mills, machining plastics, and chatter. I there is a company associated with the referanced web site, I have no affiliation with it - I just found the information interesting.
    Starting with machining plastics - from what I have found it seems that the most productive way to machine plastics in a CNC milling machine, is with router speeds, and router tool bits. That goes for soft as well as hard plastics. The information in the following site was facinating to me, as I will be using plastic materials for my applications. The information is on three related web sites: http://www.onsrud.com , http://www.plasticsmachining.com , and http://www.plasticrouting.com - they are all related to Onsrud Cutter, or seem to be. The site with the most information (they are all packed with information) is http://www.plasticrouting.com/van.asp .
    The next site contains speeds and feeds specifically for end mills, by diameter from 1/16" through 3", for premium cobalt high speed steel, and regular high speed steel, by material to be machined.
    "Chatter Myths: Pieces of the puzzle in maximized machining", the end of the article gives an example #4, of 1/4" ball mill and its natural frequencies as related to rpm, and chatter. http://www.moldmakingtechnology.com/...es/090402.html
    Proper Colleting and Collet Maintenance in CNC Routing of Plastic.
    http://www.plasticrouting.com/pdf/Pr...aintenance.pdf
    GATEWAY - Traditional Machining - Department of Mechanical Engineering, The Ohio State University - by Dr Gary Kinzel
    Milling Tips - High Speed Machining
    http://www.manufacturingcenter.com/t...99/1199ctk.asp
    The Ins and Outs of High Speed Machining
    http://www.millstar.com/techarticles/article_008.htm
    Niagra Cutter - New Concepts in Milling Handbook
    Hope you find these interesting.
    Whelen
Page 1 of 9 123
  1. High speed spindle... how high?
    By jonesja2 in forum Uncategorised MetalWorking Machines
    Last Post: 10-06-2015, 04:37 PM
  2. Sieg SX2 spindle speed
    By Hoffies in forum Benchtop Machines
    Last Post: 09-28-2013, 05:29 PM
  3. High Speed Spindle for SIEG X2 - I found it
    By whelen in forum Benchtop Machines
    Last Post: 03-30-2007, 12:50 PM
  4. Spindle speed for Sieg conversion
    By rcotteleer in forum Mach Software (ArtSoft software)
    Last Post: 01-09-2006, 07:29 AM
  5. High Speed Spindle for SIEG X2 Mill
    Last Post: 07-27-2005, 09:58 PM
