Nice work! Congrats on the build :banana:
I like that kind of frame construction Mike. I haven't noticed anyone else using round tubing for the frame and it looks very sturdy. Congratulations!
CarveOne
CarveOne
http://www.carveonecncwoodcraft.com
Very nice looking build you have there. Congratulations on your build.
Thanks guys! I plan to paint it this weekend if the weather permits.... Im thinking RED!?!?
Can't wait for pictures Sunrise Red sounds fantastic
I made a pattern using the Tube Coping Calculator from Metalgeek.com and roughed it out with a plasma cutter. Then I used the small end of a 6 X 48 belt sander to clean it up. Luckily the small end of the sander was the same diameter as the pipe and it came out almost perfect.
Thanks!
I expected there was a better way. I have a plasma cutter and figured on tracing a little less than a half circle for making a marking template if I should use pipe for anything. I have a 4 x 36 belt sander that might be closer to what I would ever need.
CarveOne
CarveOne
Looks good Mike. If the I beams are all straight and parallel with each other you're in business.
CarveOne
CarveOne
I did a good bit of cutting with it before taking it apart to paint it and everything seems to be good and straight. :-)
Looks great! I'm quite fond of the choice of color
Thanks CarveOne and Jesse! :-]
I got a little more done yesterday.. I'll try to post some pics asap!
I like it...
CarveOne
CarveOne
