585,930 active members*
3,918 visitors online*
    Aug 2007
    69
    Changing language of MAZATROL
    I have a Mazak Vertical Machining Center(Mazatrol NEXUS 510c-II) in start up position.
    It's CNC software is in German language (menues & alarms). How can I change the language to english?
    thanks
    sjh
    Jan 2010
    11
    K11
    Try taking a look at parameter K11 it is probably set to 2 which is German if you set it to 0 that should put it back in English
    Aug 2007
    69
    Dear cruiser1821
    Great!!!
    K11 is OK!!!
    It works.
    Thankssssssssssssssssssssssssss!!!!
    :cheers:
    Dec 2012
    I have a Mazak Vertical Machining Center(Mazatrol CAM M-2) in start up position.
    thanks
  1. Mazak M-4 Mazatrol T2 and mazatrol Cam T2 operating manual in english
    By tuanpq in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 07-09-2021, 04:06 PM
  2. changing the language of the screen
    By nabil_elbadri in forum Fanuc
    Last Post: 04-30-2019, 10:19 PM
  3. changing language, 802
    By emonje in forum SIEMENS -> GENERAL
    Last Post: 03-31-2010, 02:24 PM
  4. Sm1 well versed with mazatrol 640m or atleast ne mazatrol
    By naren1608 in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 03-22-2010, 11:29 AM
  5. Language change on Mazatrol Cam T2
    By andreypav in forum Mazak, Mitsubishi, Mazatrol
    Last Post: 02-14-2008, 03:23 AM
