585,973 active members*
3,851 visitors online*
IndustryArena Forum > MetalWorking Machines > Benchtop Machines > Temperature affect on Sherline
    Aug 2007
    24
    Not sure if this is splitting hair but I am curious what the temperature affect is on a Sherline, or if there is a limitation. My workshop will be in my garage and I am expecting temperature range of 0F during wintertime to 100F during summertime. Has anybody noticed any issue? Do you think I need to put a heater in the garage for sake machining? Is teflon fortified good enough? Thanks in advance.
    Aug 2009
    986
    Temperature will affect a machine's accuracy, but our benchtop machines aren't accurate enough for it to matter.
    The concern in this case is condensation. If your garage is cold and you work in it for a while, you will be putting humidity into the air, which could condense on cold metal and cause rust.
    The solution is to keep the machine well oiled.
    Frederic
    Nov 2009
    4415
    Gun care products work very well at fighting corrosion.
  1. Does ballnose diameter affect finish quality?
    By alex781 in forum CNC Tooling
    Last Post: 10-01-2010, 09:06 PM
  2. AFFECT OF MISSING BALLS IN BALL SCREW
    By Khalid in forum Machines running Mach Software
    Last Post: 01-02-2008, 02:59 PM
  3. How does PC affect speed?
    By bill south in forum Mach Software (ArtSoft software)
    Last Post: 10-13-2006, 03:05 PM
  4. Do step modes affect torque?
    By Lionclaw in forum Hobbycnc (Products)
    Last Post: 02-24-2006, 02:00 AM
  5. Paint that oil will not affect ?
    By Ken_Shea in forum Community Club House
    Last Post: 04-27-2004, 04:51 PM
