585,908 active members*
3,805 visitors online*
    Feb 2011
    16
    Thumbs up HELP sodick servo problem
    we have a sodick A320D with EX21 controller. the U servo drive has failed causing the heat switch alarm to come up.
    i have swapped the U and the V drives over to eliminate any motor or supply board problems. i have tried to get the board repaired to no avail. also the servo unit will not talk to panasonics "panaterm" software.
    does anybody know of anywhere that repairs these units in the UK or europe or if it is possible to swap them for newer type panasonic units?
    Oct 2009
    27
    I can't give you a solid answer but given your situation I would look into Panasonic. They would be able to help you best with the boards.
  1. Sodick A-280L problem
    By mikemck in forum Waterjet General Topics
    Last Post: 07-07-2014, 11:41 PM
  2. Sodick (Panasonic) servo drive
    By emexcee380 in forum EDM Discussion General Topics
    Last Post: 07-02-2012, 09:30 PM
  3. Problem in Sodick A500 nMark 21
    By puneetchawla in forum EDM Discussion General Topics
    Last Post: 03-02-2011, 12:55 PM
  4. Sodick BF275 problem in axises
    By ehsan.amouzegar in forum EDM Discussion General Topics
    Last Post: 02-07-2011, 04:18 PM
  5. sodick bw 275 re-boot & locked keyboard problem
    By john.f in forum EDM Discussion General Topics
    Last Post: 10-16-2010, 06:08 PM
