585,605 active members*
3,258 visitors online*
IndustryArena Forum > CAM Software > EdgeCam > Profile "Clearance cut" removal
    Jun 2006
    95
    I am cutting a pocket and I don't want the clearance cut loop before the tool drops to the next cut increment. How do I get rid of that? I just want to cut the profile and drop to thenext increment but staying on the path.
    Oct 2004
    38
    Hi
    In the aproach tab choose the "optimised" option in the pull down box then tick the optimised button next to it and select feed when plunging. All of the other boxes in that section i normally leave blank. Hope this helps
    Flannman
  1. Cutting slots using "Profile"
    By rickylee in forum CamBam
    Last Post: 03-07-2011, 06:57 AM
  2. User profile not respecting the selected "Theme"
    By coykiesaol in forum Autodesk
    Last Post: 12-07-2010, 07:40 AM
  3. no "jog" screen in mp3000-dthc-ubob profile
    By creepy in forum Mach Plasma / Laser
    Last Post: 01-18-2010, 01:40 PM
  4. X2 error - "warning - profile is not correct"
    By kprice1658 in forum Mastercam
    Last Post: 09-14-2007, 01:32 AM
  5. cheap DIY low profile "softjaws" vise for TAIG
    By Smertrios in forum Taig Mills / Lathes
    Last Post: 04-29-2006, 06:20 AM
