Hi gang - I really need a few suggestions...
I've got a Bridgeport running 3-axis NC on an Anliam Crusader M. Over the ~3 years I've had it, the screen would power on to display static / snow / zig-zag lines, then warm up after a few minutes. Due to lack of work (and partially lack of motivation), I've had the machine powered off for a few months. I needed to cut some simple parts last week, and found the control now only shows static, and none of the control-buttons beep either (signifying input), so I'm understanding this to be an actual control issue rather than simply one of a failed display. Additionally, attempting to put the machine into NC mode from manual fails to energize the servo drives (further reinforcing my theory).
I have pulled and re-seated all of the boards, with no effect.
I have *not* (yet) replaced the battery, though that's gonna be the next thing I'll try.
I am fortunate to have a complete spare control (minus a CRT), so I can test each board one at a time - though I believe (hope) my main controls' boards are good.
As for the battery, someone had once mentioned I can solder several CR2032 batteries together in series... (I'd have to dig up that post again).
That's where I plan to start. If anyone has any thoughts, please reply!
Thanks in advance.
