Originally Posted by
BSawyer486
Ok, Let's try another angle. Can anyone tell me where the power coming from the C41 out the 0-10v connection comes from. I am assuming that is provided by the 12vdc power supply I replaced yesterday and travels thru the c41 and is transformed to the proper voltage as determined by input from Mach3. So, this tells me something is not quite right in the language/translators in Mach3 or on the C41 board. Sooo, back to the origination of the signal. Not real sure what PWM is or how it is generated. Is the PWM Frequency supposed to be a set number, where is this number found? I have it set to 20 as shown in the PDF but is that a set value or can it be different with some machines? The Steps set in mach3 are at 1000, changing that has no affect on the output. velocity set at the 1500 max. Acceleration doesnt seem to change anything.
I guess the biggest bother to me is the C6 worked nearly perfect for so long and the C41 is supposed to work the same except for it uses PWM. After work today I will order another C6 if they are actually in stock but would really rather make this C41 work.
Ok, I'm thru, I get up way to early before work. had to kill some time.
Anyone out there that might have any suggestions would sure make my day.
Thank You,
Bruce
