Alright, I got this going on, exactly http://www.cnczone.com/forums/milltr...file_path.html at least the part in bold below.
A:\>call b:\ram\init
Bad command or file name
Loading CNC ...
A:\>b:
B:\>cd \ram
B:\RAM>a:cnc\cnc
Then just a cursor, blinking.
Looking at the Mobo, there is a Varta Nicad cell, 3.6v, 60 mah cell marked (on the mobo) BT1.
Beside it is the internal/external battery jumper, J11. Fairly obvious. switch the jumper from the two that it is on, to the other one, and the middle pin. Right?
What are the pins supposed to be on J10? 4 Pins, not marked for polarity. Is this where the external battery is supposed to be installed, and what pins are pos/neg?
Thanks.
It quit, right in the middle of homing after a batch of parts was finished. Not happy about it quitting, but finished this set anyway.
Cheers
Trev
