585,908 active members*
3,660 visitors online*
IndustryArena Forum > CAM Software > SolidCAM for SolidWorks and SolidCAM for Inventor > 2.5 D profile: How to select chain? Which operation?
Results 1 to 2 of 2
    Sep 2010
    12
    This is a follow up to the thread "How to insert tabs to part ?"
    I guess the most promising approach is to manually add tabs to the part. Now I wonder which is the most straight forward way to select the chain for the profile cut. Hand picking is quite a job for complex shapes, but I cannot figure any other at least semi-automatic way to do it.
    Furthermore: What is the best operation to profile cut this selected chain? A simple profile does only work on one z-level; doesn't it? 3d contouring does follow the path, but the tool side is not to be adjusted.
    I attach a file with the chain to further clarify the matter. As said it's still that ongoing objective to add tabs, the simple and effective way, to my parts.
    Any help is very much appreciated, Thanks a lot,
    Best, Hannes
    I dont quite understand what you're trying to cut there?
    www.wilkins-knives.com
  1. Can't select geometry?
    By phoodieman in forum Mastercam
    Last Post: 02-08-2010, 01:52 PM
  2. Profile Operation??
    By pinguS in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 02-01-2010, 04:57 AM
  3. Solidwork cam profile operation
    By kn6398 in forum Solidworks
    Last Post: 05-13-2007, 02:47 AM
  4. chain select when running BC21 on laptop?
    By Jim Estes in forum BobCad-Cam
    Last Post: 02-08-2007, 02:14 PM
  5. Help me select the right breakout
    By braidmeister in forum CNC Machine Related Electronics
    Last Post: 01-24-2007, 04:23 AM
