585,975 active members*
4,614 visitors online*
    Oct 2007
    1019
    maching out a guitar neck
    Maching out a tele guitar neck.
    An experiment as its much simpler to purchase the neck than making one.
    But i had never machines out a 3D object so this would be a good start.
    I used cut3D but it would not allow tabs 2 good heavy duty tabs at either end would have helped
    as i selected .25 overcut so there would be no scrap wood left to hold the
    neck in place.Secondly i should have allowed about 4 in at either end.
    Then you need a fairly long end mill ,mone were 1/2 flat/round end 3 in long so about 2.25 is
    ready for machining ,but i could have used about 2.75 as it was hitting the collet.
    Not sure if you can get 3.5 in 3/8 or 1/2 end mills that long.
    And its a very slow process,but did work and if i would have had better alignment when i flipped
    the blank 180 degrees it would have machined more accurate.
    Also the z=0 should be a standalone reference as when you do the first rough cut you loose your
    reference spot
    But its a start ,will improve next one
    [nomedia="http://www.youtube.com/watch?v=M_sz0TTaLiw"]YouTube - tele guitar neck experiment a 3D file form 2x4 spruce[/nomedia]
    Attached Thumbnails Attached Thumbnails neck1.jpg   neck2.jpg   holddown2.jpg   holddown7.jpg
    Oct 2007
    1019
    tried again
    tried a different method after some suggestions about doing top and bottom and it worked fine and because i used a board about 6 in wide
    i was able to add tabs which turned out very good .But i used z=0 at the bottom left and when i flipped the board i was out by 1/8
    so it looks like z=0 should be centre of the project and i also used 3/8 end mills probably a better finish.
    Turned out ok
    [nomedia="http://www.youtube.com/watch?v=tx5b41uwTd8"]YouTube - maching a guitar neck exercise this time top (fret side) and bottom[/nomedia] guitar neck 2 2nd
    [nomedia="http://www.youtube.com/watch?v=h6WNV9MXEIA"]YouTube - added tabs to the tele neck ,file ready for maching[/nomedia] cut3d video
  1. Mastercam Guitar Neck Help
    By CyborgCNC in forum Mastercam
    Last Post: 04-14-2015, 12:47 AM
  2. guitar neck
    By woodman08 in forum Musical Instrument Design and Construction
    Last Post: 02-22-2011, 06:34 PM
  3. Anyone successfully model a guitar neck?
    By rlrhett in forum Musical Instrument Design and Construction
    Last Post: 03-14-2009, 06:56 PM
  4. Guitar neck
    By David Da Costa in forum Musical Instrument Design and Construction
    Last Post: 02-04-2009, 06:41 PM
  5. guitar neck modelling....
    By anoel in forum Rhino 3D
    Last Post: 04-17-2004, 05:33 AM
