585,977 active members*
4,688 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Want To Buy...Need help! > Do I need external stepper drivers with this board?
Results 1 to 12 of 12
    Feb 2011
    Question Do I need external stepper drivers with this board?
    I am planing on purchasing a 3 axis kit for my cnc and am wondering if this kit needs additional stepper control drivers to finish it or is it built into the board? I don't think the seller can understand my question. Thank You
    Nema 23 Stepper Motor 270oz-in,3A +3 Axis Board CNC Kit - eBay (item 170608644896 end time Mar-05-11 01:32:24 PST)
    May 2008
    667
    Every thing is included in the kit
    The power supply, the board which will provide power to the 3 stepper motor
    and the breakout board to interface from parallel port to the board.
    You don't need anything more than that.
    Jeff
    15362
    catabolic
    It looks complete,But they are not saying weather it has optoiclation or not, You need this to protect your computer
    Mactec54
    Feb 2011
    Thanks Jeff, you've been a huge help for the new guy!
    Feb 2011
    Thanks mactec54, I would never have know to ask for it...you may have saved me some trouble in the long run!!!! Thanks Again
    May 2008
    667
    2, 3 Axis Driver Board
    Products Features :
    1:The maximum 3.5A drive current to a maximum 86 stepper motor drives, more powerful
    2:1-16 sub-setting, higher accuracy, smoother operation
    3:Overload over-current over-temperature protection, full protection of your computer and peripheral equipment
    4:4 files current settings can be set according to the user the actual current requirement
    5:Full closed-type optical isolation to protect the user's computer and equipment
    This is what they says about the driver board.
    Jeff
    Feb 2011
    Thanks again Jeff...I was overlooking "optical," should have double checked..too good
    Jan 2011
    but they dont tell you that this board is so bad that it might not work at all.
    May 2008
    667
    I never had good luck with those kind of board.
    Now, I always use one driver per motor.
    Sometime, with multiple driver board, when all 3 motor run at the same time,
    it look like the board cannot push all the necessary currant.
    I don't know about this particular board.
    Jeff
    Feb 2011
    that bad...have you used one...I am second guessing it myself... thanks
    Feb 2011
    could you recommend something...the most economical would be helpful. thanks jeff for all your help sorry for the late reply
    May 2008
    667
    Something like this always worked great for me.
    Stepper Motor Driver 50 DC, 4.2A on eBay.ca (item 380277121261 end time 07-Mar-11 12:58:24 EST).
    They're many model on the market or Ebay.
    Jeff
  1. Wiring up motors drivers and break out board
    By Nitroghost in forum Automation Technology Products
    Last Post: 09-22-2011, 07:41 AM
  2. Replies: 3
    Last Post: 05-22-2005, 03:55 PM
