585,978 active members*
4,298 visitors online*
IndustryArena Forum > CNC Electronics > Stepper Motors / Drives > Any one know about Soc Robotics drivers
    Feb 2011
    Hi, I'm new to cnc, I'm about half way into my cnc build. I bought a 4 axis soc robotics MK4
    http://www.soc-machines.com/pdfs/MK4...e%20Manual.pdf
    and 3 MM160 http://soc-robotics.com/pdfs/MM160%2...al%20Brief.pdf
    I see that I can set up limit switches, but can I set up home switches on this driver board? Any input would be welcome.
    Chet
    Jan 2007
    146
    Your URLs doesn't work. I looked at this: http://www.soc-machines.com/pdfs/MK4...e%20Manual.pdf
    If this is it then yes there are pin connectors to the left of the parallel connector.
    Feb 2011
    I fixed the links now, thank you.
    @jschmitt yes that is the board.
    sorry I am very new to cnc, are you talking about the white header next to the parallel port and how would I wire it? If it is the white header then I can still use the limit switch header for the limit switches.
    Thanks again,
    Chet
    Jan 2007
    146
    Quote Originally Posted by Pyro2 View Post
    Thanks again,
    Chet
    MY other left side
    there are 5 set of 2 pin connectors on the RIGHT side of the parallel port connector that are for limits and estops.
    the white header is for reprogramming the cpld chips.
    Use one of your limits as a home. If you don't want to home on the edge of your travel you can set emc or mach to make a soft limit so you can travel to your limit and the machine will stop automatically, when it reaches the limit.
    Feb 2011
    Thank you, I'll have to play with that.
  1. powermax robotics/cnc interface
    By stirling in forum Hypertherm Plasma
    Last Post: 01-25-2021, 02:42 PM
  2. rhino robotics lathe..
    By gadget47 in forum Mach Lathe
    Last Post: 06-21-2013, 05:38 AM
  3. RHINO ROBOTICS ST/7 CNC LATHE
    By airamp in forum Benchtop Machines
    Last Post: 10-01-2011, 03:46 AM
  4. US First Robotics
    By cidteach in forum Community Club House
    Last Post: 10-10-2007, 04:54 PM
  5. Adept Robotics System..not sure what to do with it
    By drewgarth in forum Servo Motors / Drives
    Last Post: 07-11-2006, 01:22 PM
