584,866 active members*
4,793 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc PMC ladder example - Sub53 AXCTL
    Aug 2010
    27
    I'm in need of another example or better explanation of the ladder programming manual. I read the maual just fine but can't get it to work so I need to see one example. No of my archive ladders are using it so I have nothing to build on.
    Specifically the Sub53 AXCTL on a SB7. I am trying to home out the indexers and move X axis while rotating the pallet changer.
    I understand the different signals to use - the 4th axis here:
    o ECLRB , G154.6 = 1 to reset clear
    o EBUFB, G154.7=, axis control command read signal
    o EAX4, G136.3, PMC control of A axis
    o EC4, G155.3=1, A axis control command
    o EID08b, G158.0, 2nd ref return
    o EDENB, F133.3=1 while moving from PMC
    o ZP24, F96.3=1, when A is at 2nd ref
    but not how to incorporate them in to the AXCTL command.
    Any thoughts,
    Burke
    Jun 2010
    161
    See attachment file for info on AXCTL function.
    Attached Files Attached Files
    Aug 2010
    27
    thanks CNC2149
    Thanks 2149 for the quick reply. Nice document. I will try to digest a little later and get back to you.
    Apr 2016
    Re: thanks CNC2149
    Quote Originally Posted by cncchewer View Post
    How about that?
    Re: Fanuc PMC ladder example - Sub53 AXCTL
    perfect, I'm troubleshooting an error on an OIF control, this helps.
  1. Help for PMC ladder for Fanuc O-M
    By giorgis in forum Fanuc
    Last Post: 09-16-2020, 10:56 AM
  2. fanuc ladder
    By poss31 in forum Fanuc
    Last Post: 05-31-2016, 04:50 AM
  3. Ladder Fanuc ^
    By CNC Machine OT in forum Fanuc
    Last Post: 09-05-2013, 06:33 AM
  4. fanuc-o ladder
    By Bill Clark in forum DNC Problems and Solutions
    Last Post: 09-29-2011, 07:35 PM
  5. Fanuc ladder
    By guhl in forum Fanuc
    Last Post: 12-07-2007, 07:54 PM
