585,949 active members*
4,274 visitors online*
IndustryArena Forum > CAM Software > OneCNC > TEXT/ENGRAVE ON VARIABLE Z
Results 1 to 11 of 11
    Oct 2010
    121
    i am trying to put some text on a variable z but. To give you an idea of what im trying to do the shape of the part is pretty much the same as the example under "engrave all variable z. Because it has multiple surfaces i have to make copy and project the whole text on every surface. The problem is when i project the text onto the surface it not only projects onto the surface but it also continues on that path right through the part, what am i doing wrong? It only does this on the downwards facing surfaces. When the surface is pointing up the text stays on the surface only so why doesnt it do this facing down?
    927
    Can you post up the file here or over at the user's forum.. a file always help..
    Oct 2010
    121
    Quote Originally Posted by wms View Post
    Ive just tried but it says its an invalid file. Its saved as an xfa file, is there something im doing wrong?
    Oct 2010
    121
    not sure whether this will work
    Attached Files Attached Files
    927
    a Dxf will be a 2d drawing..it will not have a surface in it to engrave on..You would need to save it as a Iges..or best would be to Zip up the XFA file and post it..
    Oct 2010
    121
    try this
    927
    File back with a test surface and test..
    I created a cross section surface from your edges..and projected some test text to it..then applied a tool path > "Engrave All Variable Z"..
    Hope that give you some ideas..
    Oct 2010
    121
    thanks a lot, cheers for the help!
    Oct 2010
    121
    just another quick question, how did you create the cross section surface from the edges? I have extruded model edges and then used create surface from cross section but it comes out a right mess. Do i need to select every line on the surface?
    927
    Cross section surface uses two or more sets of chains to drive the surface creations..
    I believe there are a couple of videos that demonstrate this on the user's forum..
    Oct 2010
    121
    where will i find the users forum? sorry, im not used to this site yet and dont know where to find anything
  1. I want to learn how to engrave.
    By kasari in forum WoodWorking Topics
    Last Post: 02-28-2010, 03:46 PM
  2. Need help bad, How do I engrave text
    By 2Bits in forum Dolphin CAD/CAM
    Last Post: 03-11-2009, 03:40 AM
  3. how to engrave
    By cob in forum Mastercam
    Last Post: 10-17-2008, 08:51 PM
  4. Rhino engrave text on curved surface
    By replicapro in forum Rhino 3D
    Last Post: 03-11-2008, 06:32 PM
  5. EMC2 variable pitch / variable diameter threading.
    By samco in forum MetalWork Discussion
    Last Post: 03-09-2008, 07:40 PM
