anyone knows how to drip feed on fanuc 9?
parameter setting,card option,etc?
thank's a lot
thank's a lot
The following parameters have to be set at the control and a cable configured as shown, made or bought. The cable is simple to make; use shielded cable having at least 3 wires.
Your control should have a TAPE mode. You use this mode when drip feeding (DNC) to the control. The PC software usually has a DNC mode as opposed to just Send Mode. Get the PC side ready to DNC, select TAPE mode at the control and press cycle start to run the program. All functions such as Optional Stop, Single Block, Feed Hold, Block Delete ect, all work as per normal. The only limitation is that if the program uses Sub Programs, the Subs have to be registered in the memory of the control.
Regards,
Bill
Parameters
311 = 10 (4800 Baud Rate) Starting Point
340 = 2 Input Device
341 = 2 Output Device
Control Set Page Settings
I/O = 1
ISO Format = 1
Cable pin out for Xon Xoff handshake
Machine End--------------------PC End
DB25 Male Connector----------DB25 Female-------DB9 Female
1 (Chassis ground)--------- (Not connected)--- (Not connected)
2--------------------------------3-------------------2
3--------------------------------2-------------------3
7--------------------------------7-------------------5
4 and 5 bridged
6,8,20 bridged
PC software settings
Handshake Method = Xon Xoff
Baud Rate = 4800 (Starting Point)
Data Bits = 7
Stop Bits = 2
Parity Bit = Even
Many thank's Mr. Bill,it is very useful
good luck!
regards
Rizal
