585,712 active members*
4,199 visitors online*
Results 1 to 11 of 11
    Aug 2007
    50
    Wiring Advice linear scales
    Been working on and off on my mill for several months now as time and money allows.
    It started as a Tri-Onics Handyman mill, stepper drive, Variable head. linear scales, ballscrews. Old Tri-onics controller was shoot. Good addition to my shop.
    Replaced boards with PMDX 302 breakout board and Gecko drivers, very good products. Also had to rebuild variable speed head (shim, wore shaft). I kept power supply, steppers and linear scales.
    So far I have steppers running with Mach 3 (free download for now). Tested movement with 1,2,3 block clamped to table, zeroed indicator, ran a loop program, moved 6" square both dirrections. Kept "0", was very suprised for the age of the mill.
    Here is where im at know, I want to hook up linear scales to give me a Digital readout when I want to run in as a manual (yes I want run it as a manual). I have already looked up about close looping Mach 3. I need info on hooking up the linear scales.
    +5 Vdc, A, B and common.
    Do I need a board in between scales and computer LPT2 (I already installed extra parllel part)? Or can I hook them up to the parelllel directly????????
    Attached Thumbnails Attached Thumbnails Handyman3.jpg   Handyman 001.jpg   Picture 1 004.jpg   Picture 055.jpg
    Aug 2007
    50
    Pmdx bob, gecko and power supply
    Aug 2007
    50
    I did find a Site where someone used rotaty encoder and use a Dos program for their DRO. But I was looking at using this info but the pins looked wrong. From what I have read parellel part input pins are 10, 11, 12, 13, and 15, Schematic show 2,3,4,5,6,7. SO what am I missing??????????
    http://www.lindsayengraving.com/othe...rests/dro.html
    Aug 2007
    50
    hello hello is this thing on????? I posted this days ago.
    I searched this forum for advice on Linear scales.
    I have a simply question on what are my choices, Do I have to purchase another card to use linear scales OR can I hook them up directly to a second parellel port?
    Jan 2008
    124
    From what little I know about Mach3, you can't "close the loop" with direct feedback. With EMC2 and a PICO or MESA card it is possible. EMC2 runs under Linux OS, not Windows, but it's free download. It would be best to ask this type of question in the Mach forums. You stand a better chance of getting the answers to what you ask.
    Aug 2007
    50
    I realize that Mach 3 can not give a closed loop feedback. This was not my question it was HOW to hook up the linear scales, wither with a board or directly to the parrellel poart.
    Jan 2008
    124
    A few things that you need to find out. What is the scale output ? TTL 5 volt, or 1VPP sinewave, or what? When you find out that will tell you if an interface of some type is needed. Also what DRO software are you going to use? I would think the DRO software will determine what pins to use, because the P-port pins are bi-directional, so what pins does the software read as inputs?
    24220
    I found with the Lindsay site DRO you do not need the buffer transistors, this uses a PP so you may be able to.
    Unfortunately as the Bodger says, without knowing the exact type of output of the scales you have, it is impossible to say for sure, open collector, RS420 etc?.
    All I can tell you is I tested the Linday PP version with an differential encoder directly and had good results.
    Al.
    Albert E.
    Aug 2007
    50
    It is a 5VDC, A, B channel.
    24220
    Unfortunately that does not give the whole story, at least they are not low level sine wave, It is just a case of trying it and see if it works unbuffered, or without a pull up resistor.
    There is a good chance they will.
    Pins 2~9 are the bi-directional data port, so it is being used to input the encoder signal.
    Try them with the Lindsay s/w and run that when you want to run manual if they work.
    Al.
    Albert E.
    Aug 2007
    50
    Thanks Al the man. Thats what I was looking for. Pins between the Lindsay and Mach was throwing me for a loop. Ill let you know how it works.
  1. encoders/linear scales?
    By surfjunkie in forum DIY CNC Router Table Machines
    Last Post: 06-26-2009, 07:34 AM
  2. Linear Scales Basics
    By Leha_Blin in forum Linear and Rotary Motion
    Last Post: 12-18-2008, 01:53 PM
  3. Linear Scales from CDCO Machinery?
    By jeffmorris in forum DIY CNC Router Table Machines
    Last Post: 04-26-2008, 12:08 AM
  4. VM-3 Linear Scales?
    By 100 in forum Haas Mills
    Last Post: 03-05-2007, 06:31 AM
  5. fanuc 6 and ttl linear scales
    By skippysmt in forum Fanuc
    Last Post: 02-26-2007, 12:56 AM
